8 members (Rusty Heaps, Frank50, BarryP, UtahYork, cmayna, DadsFirstPickup, Gray_Ghost, 1 invisible),
138
Mod | | | Forums66 Topics128,134 Posts1,056,738 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2020 Posts: 366 'Bolter | | 'Bolter Joined: Nov 2020 Posts: 366 | Hi All, my truck is in sig below. Is there any recommendation for protecting the under dash components of these trucks from a potential rainstorm /water getting on them. I am talking about after doing due diligence and in the case where you get a leak and water in some form hits the ignition switch/fuse box or something else..  I understand theres all types of grease but one conducts and the other doesnt and you dont want to smear the one conducting , all over the fuses and end up shorting out the whole truck OR the one that protects and then the components dont work.  . . So is there a few recommendations on the types of products or how to use them?
'38 1.5ton; "The stuff is as tough as woodpecker lips"
| | | | | Joined: May 2015 Posts: 11,120 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,120 | The first step would be making sure that water doesn't get to the electrical components in the first place. Dielectric grease could be used. Generally there won't be enough water to short out things, and rainwater shouldn't affect the primary (low voltage) wiring at all, but could possibly short the coil and spark plug wiring. A little dab of dielectric grease (mainly on the boots) will help with that. Definitely don't smear either type all over things.
Reminds me of when I was driving my Model A pickup across Kansas back in '68 when we saw a wall of water from a rainstorm coming. When it hit we couldn't see more than about 3 stripes on the interstate and the truck died from the water leaking down onto the coil, which was mounted directly below the hood hinge. I got out, was immediately soaked to the underwear, threw a tarp over the hood, dried off the coil and wiring, and restarted (still with the tarp over the hood) and found the nearest overpass to wait out the storm.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Nov 2020 Posts: 366 'Bolter | | 'Bolter Joined: Nov 2020 Posts: 366 | Ok. Thanks for the reply. Wow that must hv been scary with that model a!
| | | | | Joined: May 2015 Posts: 11,120 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,120 | Hey, I was young and indestructible back then. No big deal.
