6 members (JoergK., BarryP, Hugh63c10, Gdads51, Pre '68 Dave, 2-Ton), 315 guests, and 3 robots.
Topics128,164
Posts1,057,076
Members48,463
I looked in the search feature but didn't find an answer...But, does the 6400 use the same hood emblem as the smaller half ton trucks? if not, are they reproduced? Mine is not too pretty. Thanks guys
Big Bolt Forum Moderator
they are the same on the Task Force trucks, (55.2-59) not sure on the older ones.
Mike
COE hood emblems are different than conventional cab trucks for 47-53, so a 6400 should be the same as a 3100 and other conventional cab trucks.
They are not the same...not sure if anyone is reproducing them or not.
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
I assumed he's talking about the FRONT hood emblem. They are the same for all conventional cabs from 1/2 ton thru 2-ton. See the attached from the parts manual.
Side hood emblems are different for each size truck.
Look again Kevin, the COMM are the 1/2 to 1 ton and the UTIL are the 1-1/2 and 2 ton...different part numbers.
Mike B smile
Mike Boteler
1984 Jeep CJ7
Silver Spring, MD
The 47-53 1 1/2 ton, and 2 ton front hood emblems are slightly larger than the 1/2 ton-1 ton emblems.
Spanky Hardy
More pictures on Photobucket
1950 GMC 250 1-Ton
Mike B smile
I didn't realize that. Sorry for the misinformation.
