9 members (Cosmo, VicZ, Patina 54, Wally / Montana, Mike Burns, Ponchogl, HandyAndy, 2 invisible),
191
0
Mod | | | Forums66 Topics128,087 Posts1,055,977 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2011 Posts: 1,362 'Bolter | | 'Bolter Joined: Feb 2011 Posts: 1,362 | 1955 up. Just wondering where people are getting the complete vacuum advance and hold downs at? So far for hold downs all I have seen is an expensive cheesy, solid mount hold down for big bucks to hold a more modern non rotating distributor. Does anyone make something that is like the factory stock unit?
Kicking self for selling off my Taskforce trucks. Still looking for an LCF or conventional big bolt in decent shape.
| | | | | Joined: Sep 2011 Posts: 1,453 'Bolter | | 'Bolter Joined: Sep 2011 Posts: 1,453 |
BC 1960 Chevy C10 driver 261 T5 4.10 dana 44 power loc 1949 GMC 250 project in waiting 1960 C60 pasture art Retired GM dealer tech. 1980 - 2022 | | | | | Joined: Feb 2011 Posts: 1,362 'Bolter | | 'Bolter Joined: Feb 2011 Posts: 1,362 | Whats the phone number and address to "USED PARTS" ? Or is it more like Lotto ticket?
| | | | | Joined: Feb 2004 Posts: 29,782 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,782 | Anybody with an original part to use as a pattern can make a duplicate from a small piece of aluminum plate. I've done it pretty often. It's not "rocket surgery". Try an ad in the "parts wanted" forum- - - - -there are probably a bunch of distributors sitting around gathering dust where people have replaced them with various types of HEI units. Jerry
| | | | | Joined: Jul 2014 Posts: 362 'Bolter | | 'Bolter Joined: Jul 2014 Posts: 362 | You looking for one of these?
https://www.classicparts.com/1937-62-Vacuum-Advance-Hole-Type-6-Cylinder/productinfo/83%2D272/
https://www.classicparts.com/1937-62-Vacuum-Advance-Stud-Type-6-Cylinder/productinfo/83%2D274/ | | | | | Joined: Feb 2004 Posts: 29,782 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,782 | That's the advance unit itself- - - -for some reason, none of the resto-ripoff vendors include the bracket that attaches it to the distributor housing. Jerry
| | | | | Joined: Apr 2016 Posts: 1,043 'Bolter | | 'Bolter Joined: Apr 2016 Posts: 1,043 | I have a couple of 235's laying around. I'll check it out. Might just be easier to make it like HRL said. "It's just metal". I have a mill and a lathe.
| | | | | Joined: Feb 2011 Posts: 1,362 'Bolter | | 'Bolter Joined: Feb 2011 Posts: 1,362 | You would not to make a duplicate from aluminum, the bolt would smash it. Even the original is pretty much junk, its funny in the past years I never paid much attention to them, till now when helping someone out with their distributor install. Actually that whole system is a joke, but it has worked for how many years now? And yes there is room for improvement, but if a fellow wanted strictly stock it would be a hunting trip. The reason there are no cheap knock offs is because it would be a slightly complicated die to make them.
| | | | | Joined: Feb 2004 Posts: 29,782 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,782 | The aluminum alloy I use dulls high speed steel cutting bits on my lathe. It's considerably stronger than the original stamped steel part. Jerry
| | | | | Joined: Apr 2016 Posts: 1,043 'Bolter | | 'Bolter Joined: Apr 2016 Posts: 1,043 | Both of mine are still in trucks. It looks different than I imagined. Does that come on any other old sixes or is it 235 specific? I have some older non 235 engines in the scrap pile out back. I use almost all 6061 aluminum. It's pretty tuff stuff but I know that the 7000 and 8000 series are tougher. My Bicknel torque arm is some kind of aluminum alloy that was a nightmare to sand and polish. I think it was harder than stainless. I asked Bicknel at PRI what alloy it was and they just smiled. That being said my lathe doesn't care if it's steel or aluminum.
| | | | | Joined: Feb 2011 Posts: 1,362 'Bolter | | 'Bolter Joined: Feb 2011 Posts: 1,362 | Actually for a everyday driver truck I think the best thing to do would be the HEI distributor that is held in solid with a V-8 like advance on it, thus no rotating distributor.
| | | | | Joined: Dec 2018 Posts: 2,450 'Bolter | | 'Bolter Joined: Dec 2018 Posts: 2,450 | You would not to make a duplicate from aluminum, the bolt would smash it. Even the original is pretty much junk, its funny in the past years I never paid much attention to them, till now when helping someone out with their distributor install. Actually that whole system is a joke, but it has worked for how many years now? And yes there is room for improvement, but if a fellow wanted strictly stock it would be a hunting trip. The reason there are no cheap knock offs is because it would be a slightly complicated die to make them. You sure hit it there "Actually that whole system is a joke" We are very fortunate that HEI is adaptable and works good on stovebolt engines. Not hard to see why the Australians call it a dizzy!!
