1 members (qside), 72 guests, and 2 robots.
Topics128,049
Posts1,055,741
#1461422 08/05/2022 2:31 AM
I just had the generator rebuilt for piece of mind. Do you need to polarize it?
1953 Chevy 3100
I have recreated my Dad's old work truck with a 5 window.
2 Offline
Wouldn’t be a bad idea and causes no harm
Momentarily connect the armature to battery positive (assuming it’s a negative ground system)
One second of contact is enough
It’s gonna spark
If it’s a positive ground system then the armature gets a blast of negative
-s
Redbird,
After looking at some of your other posts, you seemed to previously indicate that your truck is currently running a 12 volt battery system.
When you had the "generator" rebuilt, did the rebuilder know you are running 12 volts and not 6 volts?
As others have noted, your '53 was originally a 6 volt system when new, but appears may have been modified to 12 volts (not uncommon) at some point afterwards.
You may want to confirm your generator is a 12 volt unit before going too much farther.
Dan
~ Dan
1951 Chevy 3 window 3100
2 Offline
Well 12 or 6 volts will polarize the system properly
If the polarity is correct
After that yeah all bets are off if the regulator and generator are not Matched to the battery smile
H Online: Content
Just wire it open- - - - -it's probably not needed anyway.
Wire it open?????
1953 Chevy 3100
H Online: Content
It works for heat riser valves, right?
Hey Jerry. I think you meant to answer my other thread. This one was on polarizing my generator.
1953 Chevy 3100
H Online: Content
I'm just applying your logic on disabling components that engineers spent millions of dollars developing. If it works on heat risers, why not generators? I spent 30+ years teaching automotive subjects at the high school and junior college level. Your heat riser opinion doesn't make good nonsense. You've already gotten the correct advice on polarizing the generator. Do it.
