2 members (DES57, 1 invisible),
142
Mod | | | Forums66 Topics128,153 Posts1,056,827 Members48,456 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2020 Posts: 68 'Bolter | | 'Bolter Joined: Jan 2020 Posts: 68 | Hello,
I have a 235 and I want to get the exhaust manifold ceramic coated because my alternator keeps going out and I think it is because of the heat. My alternator is right above the manifold, and I tested it with a thermometer and the alternator got to 160F. My concern is the manifold will not get hot enough to cause the thermostatic spring to close the flange that put exhaust on the bottom side of the carb to warm the gas during the initial starting up phase when the engine is still cold. Does anyone have any suggestions or experience with this problem, thanks?
Mike
Mike
| | | | | Joined: Oct 2021 Posts: 6,923 'Bolter | | 'Bolter Joined: Oct 2021 Posts: 6,923 | 160F isn't really hot and certainly well within the range that an alternator can tolerate.
300F is around the temperature that an alternator starts having problems.
Your alternator should be able to run indefinitely at 160F.
You have another problem causing your alternator to fail, in my opinion.
1950 Chevrolet 3100 (Ol' Roy)
| | | | | Joined: Feb 2000 Posts: 5,228 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,228 | The spring will still work with manifold coatings, none of them insulate so good the spring won't relax. | | | | | Joined: Dec 2018 Posts: 2,450 'Bolter | | 'Bolter Joined: Dec 2018 Posts: 2,450 | Mike Bell Check your battery voltage to see if alternator is overcharging. | | | | | Joined: Mar 2007 Posts: 3,433 Crusty Old Sarge | | Crusty Old Sarge Joined: Mar 2007 Posts: 3,433 | If this becomes an electrical question you need to move it to The Electrical Bay.
~ Craig 1958 Viking 4400"The Book of Thor"Read the story in the DITY1960 Chevrolet C10"A Family Heirloom"Follow the story in the DITY Gallery'59 Apache 31, 327 V8 (0.030 over), Muncie M20 4 Speed, GM 10 Bolt Rear... long term project (30 years and counting) If you don't like driving yourTruck, you won't drive yourTruck..| Living life in the SLOW lane | | | | | Joined: Jan 2020 Posts: 68 'Bolter | | 'Bolter Joined: Jan 2020 Posts: 68 | Thanks for all the replies. I am going to go ahead and get it coated, whether that fixes the alternator problem I have been having or not, it looks good and will still reduce under the hood heat.
Mike
| | | | | Joined: May 2015 Posts: 11,131 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,131 | Thanks for all the replies. I am going to go ahead and get it coated, whether that fixes the alternator problem I have been having or not, it looks good and will still reduce under the hood heat. Don't count on on ceramic coating to reduce underhood heat much at all. If you chose a light color it would reduce the radiation component of the total heat released from the hot manifold. The bulk of the heat is released by convection (probably 95%), so you MIGHT get a 5% reduction in under hood temperature, but I doubt it.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Jan 2022 Posts: 2,481 'Bolter | | 'Bolter Joined: Jan 2022 Posts: 2,481 | Would exhaust manifold heat shield wrap help?
'57 GMC 102, Original 347 V8, HydraMatic, 3.08 rear gear, added A/C, disk front brakes, HEI, AFB carb, '98 Honda Black Currant paint. T-boned and totaled 10/12 '52 GMC 152 Stake Bed, Original 228, SM420, added A/C, HEI, disk front brakes, '67 Chev 3.55 rear gear. Gets used as a real truck.
| | | | | Joined: Oct 2021 Posts: 6,923 'Bolter | | 'Bolter Joined: Oct 2021 Posts: 6,923 | Help with the alternator problem? No.
Help reduce underhood temps? Probably, at least a little.
| | | | | Joined: Feb 2004 Posts: 29,850 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,850 | An aluminum shield will do a lot more to deflect heat away from the alternator than spending a ridiculous amount of money on ceramic coating. I've seen underhood temps well over 200 degrees on a summer day, so the idea that heat is causing the alternator problems doesn't make good nonsense. Try using a remote BBQ thermometer under the hood and measure the temp while you're driving down the road with plenty of air flowing- - - -it should be a lot lower. The new remote I've started using while smoking pork butts will transmit up to 90 feet, and I'm already thinking up ways to make use of it for diagnosing automotive problems. Jerry
| | | | | Joined: Feb 2000 Posts: 5,228 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,228 | The better heading coatings available will help cool the manifold, but it needs to be coated inside and out. But wait, now you also need to coat the exhaust pipe because all the heat from the exhaust will now radiate out though the pipe. Header wrap will also keep heat heat in, but you will need a couple of manifolds due to the heat cracking and warping of the extra hot manifold. Headers do the same thing if when street driven. A simple air duct will do more for cooling the alternator then the coatings would. | | |
