6 members (RAC1812, klhansen, Gdads51, joe apple, tesa, Gray_Ghost), 54 guests, and 0 robots.
Topics128,077
Posts1,055,928
Members48,430
#1461288 08/03/2022 4:51 PM
1955 up. Just wondering where people are getting the complete vacuum advance and hold downs at? So far for hold downs all I have seen is an expensive cheesy, solid mount hold down for big bucks to hold a more modern non rotating distributor.
Does anyone make something that is like the factory stock unit?
Used parts.
BC
1960 C60 pasture art
Whats the phone number and address to "USED PARTS" ?
Or is it more like Lotto ticket?
Anybody with an original part to use as a pattern can make a duplicate from a small piece of aluminum plate. I've done it pretty often. It's not "rocket surgery". Try an ad in the "parts wanted" forum- - - - -there are probably a bunch of distributors sitting around gathering dust where people have replaced them with various types of HEI units.
You looking for one of these?
https://www.classicparts.com/1937-62-Vacuum-Advance-Hole-Type-6-Cylinder/productinfo/83%2D272/
https://www.classicparts.com/1937-62-Vacuum-Advance-Stud-Type-6-Cylinder/productinfo/83%2D274/
That's the advance unit itself- - - -for some reason, none of the resto-ripoff vendors include the bracket that attaches it to the distributor housing.
I have a couple of 235's laying around. I'll check it out. Might just be easier to make it like HRL said. "It's just metal". I have a mill and a lathe.
You would not to make a duplicate from aluminum, the bolt would smash it. Even the original is pretty much junk, its funny in the past years I never paid much attention to them, till now when helping someone out with their distributor install.
Actually that whole system is a joke, but it has worked for how many years now? And yes there is room for improvement, but if a fellow wanted strictly stock it would be a hunting trip.
The reason there are no cheap knock offs is because it would be a slightly complicated die to make them.
The aluminum alloy I use dulls high speed steel cutting bits on my lathe. It's considerably stronger than the original stamped steel part.
Both of mine are still in trucks. It looks different than I imagined. Does that come on any other old sixes or is it 235 specific? I have some older non 235 engines in the scrap pile out back. I use almost all 6061 aluminum. It's pretty tuff stuff but I know that the 7000 and 8000 series are tougher. My Bicknel torque arm is some kind of aluminum alloy that was a nightmare to sand and polish. I think it was harder than stainless. I asked Bicknel at PRI what alloy it was and they just smiled. That being said my lathe doesn't care if it's steel or aluminum.
Actually for a everyday driver truck I think the best thing to do would be the HEI distributor that is held in solid with a V-8 like advance on it, thus no rotating distributor.
You sure hit it there "Actually that whole system is a joke" We are very fortunate that HEI is adaptable and works good on stovebolt engines. Not hard to see why the Australians call it a dizzy!!
