| | | Forums66 Topics128,020 Posts1,055,345 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2011 Posts: 187 'Bolter | | 'Bolter Joined: May 2011 Posts: 187 | Looking to replace the window channel on both doors on my 1950 Chevy 3800 series. No fabric left on either after all these years so what is visible is the so called corrugated metal. It appears that there is a staple or something holding them to the door about every 6" give or take. Will these be difficult to remove from the doors, are they just yanked out? Are the new replacements also secured in a similar way? I'm also assuming the new ones will need to be cut to length and bent to the proper shape. Any info. or suggestion, or advice on doing this job is appreciated.
Thanks, Tom | | | | | Joined: Nov 2021 Posts: 1,258 'Bolter | | 'Bolter Joined: Nov 2021 Posts: 1,258 | From my experience on similar windows from the 60's and 70's those little staples hang on with the force of a 1000 suns. They will be destroyed by the time you get them out.
Going in the struggle is not to scratch the door up too badly. | | | | | Joined: Apr 2007 Posts: 1,038 'Bolter | | 'Bolter Joined: Apr 2007 Posts: 1,038 | Try using #4 flat head 1/4inch sheet metal screws after drilling proper size hole. The head will bury itself in the fabric and not interfere with the glass. Kent | | | | | Joined: Feb 2019 Posts: 4,472 AD Addict & Tinkerer | | AD Addict & Tinkerer Joined: Feb 2019 Posts: 4,472 | I used a pop rivets to secure the channels. Like the screw, they will bury in the felt.
Phil Moderator, The Engine Shop, Interiors and Project Journals1952 Chevrolet 3100, Three on the Tree, 4:11 torque tube Updated to: ‘59 235 w/hydraulic lifters, 12v w/alternator, HEI, PCV and Power front Disc BrakesProject JournalsStovebolt Gallery Forum | | |
