1 members (Truckrolet),
156
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,115 Posts1,056,291 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2002 Posts: 69 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2002 Posts: 69 | has anyone converted the old 68 C60 single style master cylinder brake system over to dual ?
what master cylinder and distribution block would you use ?
4 wheel drums
i was thinkign to use 67-70 C-30 m/c and distrib bloc, but would that m/c have a big enough piston in it ?
it would work wouldnt it ?
thanks for anything!
Randy the easter wabbit ! -here to help fellow enthusiasts as best as possible  parting some vehicles, 54 ford truck 57, chevy 210, 69 fairlane coupe HT and others, | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy Fast 68, I would look for a later dual master and valving from a similar size truck, I wouldn't try using any thing from a smaller truck for capacity reasons. | | | | | Joined: Oct 2002 Posts: 69 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2002 Posts: 69 | hi 3B, thanks
well i was thinking the same, but the firewall and pedals assembly isnt the same in 73-up
thats alot of modification
hmmm
the reason why i am asking this is because the m/c on the C-60 is dying and so i have to get a new one anyways, if such one can be found,
i figured the m/c for the '67-70 30 series with the big optional 11k lb 10 bolt axle would be pretty darn good, larger than 1-1/8" bore i know
thanks for any further
Randy the easter wabbit ! -here to help fellow enthusiasts as best as possible  parting some vehicles, 54 ford truck 57, chevy 210, 69 fairlane coupe HT and others, | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | You will have to use 2 hydravacs also. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
