8 members (Maybellene, 2-Ton, klhansen, carbking, Peggy M, Wayne67vert, Otto Skorzeny, gswbbc), 103 guests, and 4 robots.
Topics128,042
Posts1,055,497
Members48,424
#146098 03/14/2006 10:39 PM
Junior Member
Junior Member
May 48 has no brake lights! I need to know where the wires connect from the brake light switch. I know one of them hooks to the fuse and the other (?) Does it connect to the dimmer switch?
Thanks in advance.
naylor
36 Chevy 2 dr sedan
48 dumper 1 1/2
64 Chevelle 2 dr HT
51 F1 pick-up
52 F1 pick-up
several stationary motors
many old tractors
#146099 03/14/2006 11:49 PM
Riding in the Passing Lane
No. If it has turn signals in combination with stop lights it goes to the turn switch. If not it goes right back to the rear lights. Put a test light on the swtitch terms. One should be hot all the time. The other should light the light when the brakes are applied. If it doesn,t the switch is bad. If its good you will have to trace it.
1972 Chevy c10 Cheyenne Super
#146100 03/15/2006 2:11 AM
Junior Member
Junior Member
I knew that! It's been a long day and I can't think anymore. I'll start again tomorrow.
naylor
36 Chevy 2 dr sedan
48 dumper 1 1/2
64 Chevelle 2 dr HT
51 F1 pick-up
52 F1 pick-up
many old tractors
