| | | Forums66 Topics128,037 Posts1,055,469 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2006 Posts: 14 Junior Member | | Junior Member Joined: Jan 2006 Posts: 14 | May 48 has no brake lights! I need to know where the wires connect from the brake light switch. I know one of them hooks to the fuse and the other (?) Does it connect to the dimmer switch? Thanks in advance.
naylor 36 Chevy 2 dr sedan 48 dumper 1 1/2 64 Chevelle 2 dr HT 51 F1 pick-up 52 F1 pick-up several stationary motors many old tractors
| | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | No. If it has turn signals in combination with stop lights it goes to the turn switch. If not it goes right back to the rear lights. Put a test light on the swtitch terms. One should be hot all the time. The other should light the light when the brakes are applied. If it doesn,t the switch is bad. If its good you will have to trace it. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Jan 2006 Posts: 14 Junior Member | | Junior Member Joined: Jan 2006 Posts: 14 | I knew that! It's been a long day and I can't think anymore. I'll start again tomorrow.
