3 members (RLB, Gdads51, Joe H), 153 guests, and 3 robots.
Topics128,091
Posts1,056,390
Members48,442
I am in the process of replacing the rear wheel cylinders on my 46 2 ton. The passenger side went smoothly. Upon disassembling the drivers side, I noticed that the thrust washer that goes between the outer bearing and the inner spindle nut is missing. I am having absolutely no luck locating one. Any advice will be greatly appreciated.
I found the crimped lock washers that go in front of it on the internet with help from a fellow Bolter. Good Luck
Can you provide some measurements from the washer that you have? Picture would be good as well.
Lots more pictures
