| | | Forums66 Topics128,091 Posts1,056,387 Members48,442 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2022 Posts: 15 'Bolter | | 'Bolter Joined: Jul 2022 Posts: 15 | I am in the process of replacing the rear wheel cylinders on my 46 2 ton. The passenger side went smoothly. Upon disassembling the drivers side, I noticed that the thrust washer that goes between the outer bearing and the inner spindle nut is missing. I am having absolutely no luck locating one. Any advice will be greatly appreciated. | | | | | Joined: Feb 2010 Posts: 476 'Bolter | | 'Bolter Joined: Feb 2010 Posts: 476 | I found the crimped lock washers that go in front of it on the internet with help from a fellow Bolter. Good Luck | | | | | Joined: Nov 2011 Posts: 1,611 'Bolter | | 'Bolter Joined: Nov 2011 Posts: 1,611 | Can you provide some measurements from the washer that you have? Picture would be good as well. | | |
