0 members (), 133 guests, and 4 robots.
Topics128,186
Posts1,057,211
Members48,465
Anyone have a source other than the resto rip off places. 1$+ for one bolt is ridiculous.
Sir Searchalot
Sir Searchalot
Don't see any reason to use those. They are in unseen places. Talk yourself out of it. But I'll look for you.
Find someone in parting tractors. They use those. That will be cheap.
Get on these type forums and post away. https://www.mytractorforum.com/threads/thoughts-on-parting-tractors.536569/
bartamos, they are seen. They mount the rear fenders and are visible from the inside the bed. I like the unusualness of them. I’ll search your link.
Sir Searchalot
Sir Searchalot
thumbs_up Well OK then. I see. Of course, don't pass up any length longer than 3/4 as you know. Cut em off and thread em.
Martin, I just browsed around for those yesterday, and there are a couple of places that sell full sets for a touch less than $1/bolt. I don't recall where that was though. I think you may just have to pay the piper. I haven't found anywhere that sells them for less. Even my go-to hardware spot (McMaster-Carr) doesn't have them. frown On the other hand, I just saw that Brother's truck sells a set of 20 for $79 and it didn't even say they were stainless. big_eek
I know that they are not authentic but I am planning to use torx pan head bolts. They appear similar except the shape of the internal drive feature and are more readily available.
1949/50 3600 Project
Follow in Project Journals
And the fact that the torx is something that you can get out!
BC
1960 C60 pasture art
Check out Mr G's.
Mr. G’s Enterprises Automotive fasteners, of all types
5613 Elliot Reeder Road
Fort Worth, Texas 76117-6013
817-831-3501 or 817-838-3131
https://mrgusa.com/
Even if you don't get the clutch heads, he has every oddball type of fastener you can imagine. His website is also a good reference to identify oddball fasteners and clips, etc. If you can't find them in his catalog, give him a call. He's pretty helpful.
His catalog pages will print out with the fastener profiles and heads in actual size so you can lay your existing part over the picture to verify correct fit.
1950 Chevrolet 3100 (Ol' Roy)
Thanks Otto, I’ll have to call. They do not list clutch heads in the published information but considering their business caters to concourse restoration folks the bolts may just be stashed away somewhere.
Insomniac
Insomniac
Gord 🇨🇦
1954 1/2 ton 235 4 speed
Sir Searchalot
Sir Searchalot
Right now he wants Clutch Head.
Classic truck has exactly what he wants. But they are $1.25. minus discount.
Martin, life is short, bite the bullet and buy them. The 5/8 long are 99 cents minus discount. Some yahoo on Classic wrote 5/8 "dia". May work. just 1/8 short. See the 41-54 fender screw.
No washers for the 5/8, locktite
https://www.classicparts.com/1941-5...pYRJatDCQ_rie8BesVd2crZ7dBhoCi2oQAvD_BwE
Gord, I have access to those at our local Mom and Pop hardware store or Tractor Supply.
bartamos, I have looked at those and the same ones at the other suppliers. I could “bite the bullet” easily enough but I’m really not that much of a purist especially with this restomod truck. I just thought if Clutch Heads were readily available in bulk I would put them back on. Since they are not I’ll probably go with the local hardware store stuff.
Thanks everyone.
Did you try Fastenal.com They have most every kind of bolt/screw one would need.
1936 GMC T-14 restro-mod
Fastenal Store just 2 miles from my house. First place I checked. No go.
Maybe they go by another name? Or maybe he lists them as something else, like GM bolts or something. As much stuff as he has, I'd be surprised if he doesn't at least know what they are or who else might have them.
