0 members (),
81
Mod | | | Forums66 Topics128,179 Posts1,057,160 Members48,465 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2005 Posts: 7,441 Bolter | | Bolter Joined: Apr 2005 Posts: 7,441 | Anyone have a source other than the resto rip off places. 1$+ for one bolt is ridiculous.
| | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | Don't see any reason to use those. They are in unseen places. Talk yourself out of it. But I'll look for you. Find someone in parting tractors. They use those. That will be cheap. Get on these type forums and post away. https://www.mytractorforum.com/threads/thoughts-on-parting-tractors.536569/
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Apr 2005 Posts: 7,441 Bolter | | Bolter Joined: Apr 2005 Posts: 7,441 | bartamos, they are seen. They mount the rear fenders and are visible from the inside the bed. I like the unusualness of them. I’ll search your link.
| | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 |  Well OK then. I see. Of course, don't pass up any length longer than 3/4 as you know. Cut em off and thread em.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: May 2015 Posts: 11,163 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,163 | Martin, I just browsed around for those yesterday, and there are a couple of places that sell full sets for a touch less than $1/bolt. I don't recall where that was though. I think you may just have to pay the piper. I haven't found anywhere that sells them for less. Even my go-to hardware spot (McMaster-Carr) doesn't have them.  On the other hand, I just saw that Brother's truck sells a set of 20 for $79 and it didn't even say they were stainless.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Nov 2021 Posts: 1,403 'Bolter | | 'Bolter Joined: Nov 2021 Posts: 1,403 | I know that they are not authentic but I am planning to use torx pan head bolts. They appear similar except the shape of the internal drive feature and are more readily available. | | | | | Joined: Sep 2011 Posts: 1,459 'Bolter | | 'Bolter Joined: Sep 2011 Posts: 1,459 | I know that they are not authentic but I am planning to use torx pan head bolts. They appear similar except the shape of the internal drive feature and are more readily available. And the fact that the torx is something that you can get out!
BC 1960 Chevy C10 driver 261 T5 4.10 dana 44 power loc 1949 GMC 250 project in waiting 1960 C60 pasture art Retired GM dealer tech. 1980 - 2022 | | | | | Joined: Oct 2021 Posts: 6,951 'Bolter | | 'Bolter Joined: Oct 2021 Posts: 6,951 | Check out Mr G's. Mr. G’s Enterprises Automotive fasteners, of all types 5613 Elliot Reeder Road Fort Worth, Texas 76117-6013 817-831-3501 or 817-838-3131 https://mrgusa.com/Even if you don't get the clutch heads, he has every oddball type of fastener you can imagine. His website is also a good reference to identify oddball fasteners and clips, etc. If you can't find them in his catalog, give him a call. He's pretty helpful. His catalog pages will print out with the fastener profiles and heads in actual size so you can lay your existing part over the picture to verify correct fit.
1950 Chevrolet 3100 (Ol' Roy)
| | | | | Joined: Apr 2005 Posts: 7,441 Bolter | | Bolter Joined: Apr 2005 Posts: 7,441 | Thanks Otto, I’ll have to call. They do not list clutch heads in the published information but considering their business caters to concourse restoration folks the bolts may just be stashed away somewhere.
| | | | | Joined: Jul 2000 Posts: 2,204 Insomniac | | Insomniac Joined: Jul 2000 Posts: 2,204 |
Gord 🇨🇦 ---- 1954 1/2 ton 235 4 speed | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | Right now he wants Clutch Head. Classic truck has exactly what he wants. But they are $1.25. minus discount. Martin, life is short, bite the bullet and buy them. The 5/8 long are 99 cents minus discount. Some yahoo on Classic wrote 5/8 "dia". May work. just 1/8 short. See the 41-54 fender screw. No washers for the 5/8, locktite https://www.classicparts.com/1941-5...pYRJatDCQ_rie8BesVd2crZ7dBhoCi2oQAvD_BwE
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Apr 2005 Posts: 7,441 Bolter | | Bolter Joined: Apr 2005 Posts: 7,441 | Gord, I have access to those at our local Mom and Pop hardware store or Tractor Supply.
bartamos, I have looked at those and the same ones at the other suppliers. I could “bite the bullet” easily enough but I’m really not that much of a purist especially with this restomod truck. I just thought if Clutch Heads were readily available in bulk I would put them back on. Since they are not I’ll probably go with the local hardware store stuff.
Thanks everyone.
| | | | | Joined: Oct 2012 Posts: 340 'Bolter | | 'Bolter Joined: Oct 2012 Posts: 340 | Did you try Fastenal.com They have most every kind of bolt/screw one would need.
1936 GMC T-14 restro-mod
| | | | | Joined: Apr 2005 Posts: 7,441 Bolter | | Bolter Joined: Apr 2005 Posts: 7,441 | Fastenal Store just 2 miles from my house. First place I checked. No go.
| | | | | Joined: Oct 2021 Posts: 6,951 'Bolter | | 'Bolter Joined: Oct 2021 Posts: 6,951 | Thanks Otto, I’ll have to call. They do not list clutch heads in the published information but considering their business caters to concourse restoration folks the bolts may just be stashed away somewhere. Maybe they go by another name? Or maybe he lists them as something else, like GM bolts or something. As much stuff as he has, I'd be surprised if he doesn't at least know what they are or who else might have them.
