0 members (), 160 guests, and 5 robots.
Topics128,149
Posts1,056,818
Members48,456
#146020 03/09/2006 6:01 PM
I'm new to the big truck stuff...I've got this 1952 GMC 350 dump truck and don't know what size it would be..
Here's some data off the plate on the A pillar..
Serial No. 354 24 S 1152
Gross Wt. 16,000
Max Gross Wt. 26,000
I bought the truck to get the 302 out of it to put into my '50 Chevy Fleetline. Before I pass it off or part some of it, I would like to know if it's a 1 1/2 or 2 ton or what?
Any help appreciated..and thanks in advance...
[img]http://pic12.picturetrail.com/VOL424/525201/1528767/132489810.jpg[/img]
50sChevys
#146021 03/09/2006 9:49 PM
It's a 2 ton
Geoff. Chadwick
Priest River, Id
49 Chev 4400
51 GMC 350 Dump
59 Chev Apache 32
JD 420C w/ Loader
RD4 Cat w/ Blade
Geoff
68 GMC 3800
56 JD420C w/JD90 Loader
#146022 03/09/2006 10:15 PM
Unless someone switched engines, in the past. That 350 series, 2 ton, '52 model GMC truck, came with a 248 in it, from the factory. That's what the "24", in the Data plate number stands for. The 302's came in the, 450 series 3 ton, & 470 series 3 1/2 ton GMC's. If you do indeed see "302", stamped, on the flat ledge, at the base of the distributor. The orig. motor, has been swapped.
Spanky Hardy
More pictures on Photobucket
1950 GMC 250 1-Ton
#146023 03/09/2006 10:35 PM
I'll take the grille. wink
1954 GMC De Luxe COE
#146024 03/10/2006 1:28 AM
The engine has been pulled and is at the machine shop. However, the casting number on the block is 2193980 which indicates is it a 302. Somewhere in its life, the original probably gave it up...
Thanks for the info..
50sChevys
#146025 03/11/2006 10:46 PM
I want the rest of truck!!! Cept it's in Neverland and I can't reach that far! Darnnn!
Hackers, you never know when to leave a nice truck alone, do ya!
G.L. Grumpy's
Old Iron Ranch
Huntington, IN 46750
MM R tractor, Speedex
and Power King tractors
#146026 03/11/2006 10:50 PM
Big Bolt Shop Curmudgeon
50s Chevys you've got a good lookin' truck there.
If all you want is the engine, I'm sure you can find somebody to take the rest of it off your hands.
There's a whole bunch of 'Bolters just east of you in the Metroplex, plus Cletis out there in Parker County.
Texan's seem to hoard old Chevy and GMC trucks, so you are in good company.
Here's a thought: Why not keep the truck and fix it up, then git yerself another engine for the Fleetline.
Drivin' down a 2 lane country road in a stovebolt.....cowboy, it don't get no better than this!
1946 1-1/2 ton Chevy
"Ol Blue", or "THE BIG 'UN"
#146027 03/13/2006 3:11 AM
Well, first of all...I'm not going into how many vehicles I've "saved" in the last 18 years..I hardly think I qualify as a "hacker" and I don't have the desire to do anything unbecoming to this particular '52 GMC truck. This wasn't the original engine in this truck anyway...The head on the 302 in this truck was cracked, but I was able to salvage the "short block", etc. I've had to go through the expense and frustration of dealing with four (4) consecutive cracked heads in a row in my search for a good 302...Not funny and not cheap in the process. Finally, I have found a good 302 head which has been rebuilt and pressure tested OK...
Quote
Glenn, if you can give me "Cletis" email address or how to contact, I will see if he wants to come over and take this truck home... He's an hour and 15 minutes away..
Thanks in advance..
Jack Jenkins
Web Site
50sChevys
#146028 03/13/2006 4:33 AM
Jack, I sent you an email.
#146029 03/13/2006 6:31 AM
cletis...I'll take the grille...and that stock antenna. :p I guess it has a radio...that'll make it worth your while.
