4 members (Steelonsteel, frogfarmer, Chris's 46 / 515, JW51), 120 guests, and 4 robots.
Topics128,269
Posts1,058,402
Members48,485
#1460220 07/25/2022 10:36 PM
1950 Chevy 3100 216 3 Speed.
I drove the truck up until the time I started the off frame of restoration. I did things a bit backwards. I rebuilt the engine then started the body work. It’s a rabbit hole as you all know. That we April 2020. Now that I am finished I figured I would simply add gas and drive again, but not so. I filled the bowl with gas, put the carb back together, and expected to drive off into the sunset. But that was not what happened. If I pour some gas into the carb the truck runs. But once that gas is gone the engine stops. I’m assuming one of the needle valves is stuck. I’m looking for your advice. Thank you. 216 with single barrel Rochester carburetor.
Darren
Current Project - 1950 3100 5 Window with a rebuilt 216 and 3 speed trans
HI Darren,
Start at the beginning. Check if there is fuel in the tank, check if the petcock is open (if there is one of course). Is fuel getting to the pump? Is the pump out putting fuel at the correct pressure and volume? Is fuel getting through the filter? Then you check if the carburetor needle valve is stuck.
If you just want a shortcut, try rapping the carb near the fuel valve with the handle of a screwdriver a few times with it running and see if that helps.
Steve
Steve
1946 1/2 ton
Carburetion specialist
The engine will run with fuel in the carburetor; therefore you have a fuel delivery system issue.
Test the fuel delivery system backwards.
(1) disconnect fuel line from carb and crank engine; is there any fuel with pressure?
(2) If yes, rebuild carb. If no, disconnect fuel line from tank to fuel pump and add a second fuel source, possible a marine tank?
(3) With new source to fuel pump repeat test one; is there any fuel?
(4) If no, remove fuel pump and check cam lobe; if good rebuild fuel pump
(5) Back to three; if yes, pump is working, and the problem probably is in the tank; which probably should now be dropped.
May be somewhat messy, but not difficult; just do your testing.
Jon
The Carburetor Shop
A clear fuel filter is a cheap visual aid. Try priming the fuel pump by funneling fuel back through the line from the carburetor. I had to do this on an aftermarket pump.
I invest my money in precious metals, mostly rust!
