8 members (sron48, KCMongo, Nick in Manitou, Otto Skorzeny, MickeyP, mick53, Gdads51, Jaison), 102 guests, and 2 robots.
Topics128,050
Posts1,055,704
#1459080 07/17/2022 7:20 PM
What wt oil/fluid and make does everyone use in a SM 420 transmission?
Also are there any additives that could be used to improve shifting?
thanks Doug
dougs #1459086 07/17/2022 8:00 PM
90 weight straight mineral oil- - - -NOT any of the synthetics, multi-weight lubes like 85/140 or "mouse milk" additives, or anything fancy. The gears in a 420 are heavy and have a lot of inertia, and the super slippery lubes don't let the synchronizer blocker rings get enough traction on the gears to match up speed during shifting and prevent grinding. The 90 weight mineral oil Tractor Supply sells for Ford N-series tractors is the correct lube for the 420 transmission.
dougs #1459145 07/18/2022 2:44 AM
dougs #1459179 07/18/2022 2:22 PM
NAPA also carries 90w mineral oil, part# 65-201. Runs about $35/gal.
Ed
dougs #1459181 07/18/2022 2:27 PM
Jerry, Do you have a part # for Tractor Supply? I can't seem to find it. Tks Ed
Ed
dougs #1459183 07/18/2022 2:45 PM
AD Addict & Tinkerer
Here is a [Link].
Phil
Project Journals
Stovebolt Gallery Forum
dougs #1459216 07/18/2022 6:52 PM
Thanks, guess NAPA is pretty reasonable after all. Ed
Ed
dougs #1459243 07/18/2022 9:04 PM
7
7 Offline
I used Valvoline SM transmission lube, got it Qt. bottles at one of the auto chain stores, works great.
