| | | Forums66 Topics128,154 Posts1,056,856 Members48,456 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2020 Posts: 197 1950 Chevy 3100 216 3 Speed. | | 1950 Chevy 3100 216 3 Speed. Joined: Jun 2020 Posts: 197 | I have a 1950 3100 with a 12V system and I am about to wire up the tail lights. The tail lights I bought have two bulbs and two wires. Is it possible to wire the brake light and the turn signal light into the same circuit?
Darren Current Project - 1950 3100 5 Window with a rebuilt 216 and 3 speed trans
| | | | | Joined: Apr 2005 Posts: 2,832 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,832 | Yes, if you have a turn signal with 7 wires it is meant to have the brake light and t/s work on the same wire.
Evan
| | | | | Joined: Jun 2020 Posts: 197 1950 Chevy 3100 216 3 Speed. | | 1950 Chevy 3100 216 3 Speed. Joined: Jun 2020 Posts: 197 | I have a turn signal with 7 wires but the wiring diagram is long gone. If you have one could you please post. Thank you.
| | | | | Joined: May 2015 Posts: 11,134 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,134 |
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Dec 2018 Posts: 2,450 'Bolter | | 'Bolter Joined: Dec 2018 Posts: 2,450 | Chevy Darrin That diagram is on the internet,it only takes 3 wires to run the tail lights,stop lights and turn signals . stop and turn signals will interchange as you use them. You'll feel like a wiring guru when that works for you !! Not hard to get them interchanged...keep at it you'll hit it !! | | | | | Joined: Jun 2020 Posts: 197 1950 Chevy 3100 216 3 Speed. | | 1950 Chevy 3100 216 3 Speed. Joined: Jun 2020 Posts: 197 | Thanks for the advice. Once I understood what had to happen and accepted that I had to use the wire off the brake light switch it all made sense. Got the flasher nicely mounted on the left side kick panel up out of sight. Turned out great. On this truck in the 70’s I had mid 70’s Chevy step side top lights and a two wire brake and signal light. The way the one wire light works is cool. Cheers again to everyone that responds and gives great advice.
