5 members (Jay R, Hugh63c10, lc_btv, SNOYL, 1 invisible), 70 guests, and 4 robots.
Topics128,050
Posts1,055,673
#1458549 07/12/2022 9:30 PM
Can someone tell me about this engine? Year and size.
thanks
~ BD.
1958 Apache Stepside
1958 Apache 1/2 ton Panel
1959 Apache 1/2 ton Panel
Guitplayer #1458570 07/12/2022 10:38 PM
The 3756519 block casting was used from '58-'62 and is a 283 cu.in. engine. The date code, if I'm reading it correctly from the first photo ends in a zero, which would date the casting to 1960. Looks like B 1 0, which decodes to February 1st, 1960.
The spread-bore 4bbl intake manifold and valve covers appear to be from a later engine or engines. Heads may be mid-60's based on the casting style and end-marking.
Chevy introduced the spread-bore Quadrajet on the 396 in '65, and also used that on small blocks starting with the 327. I don't believe the spread-bore manifold/carb combination was ever used on 283s from the factory, but not positive on that - possibly in '66 when there was a 4bbl 283.
Good resource here on SBC casting numbers and stamped engine numbers.
Doug
1947 2nd-Series GMC FC152 3/4-ton
Follow the story in the DITY
1953 Chevy Bel Air Sport Coupe Powerglide
Guitplayer #1458575 07/12/2022 11:23 PM
The heads are "power pack" high compression items used on 265 and 283 engines- - - -with 58 CC combustion chamber volume and relatively small intake and exhaust valves. They provide plenty of compression pressure, but the gas flow is somewhat restricted due to the small valves. The intake will be from a mid to late 1960's 327, or more likely a 350 with an early version of the Quadrajet carbutretor. Later models did not have the slot for exhaust gas from the heat riser, or the oil filler tube at the front near the thermostat housing. If you wanted to upgrade the heads and intake to later production items, there are 58CC heads with bigger valves from a late 1970's or early 80's 305, and an aluminim Q Jet manifold that would be a bolt-on swap to the ones currently on the engine. 283's use a "small rod journal" crankshaft with a 2.00 inch diameter rod bearing and smaller diameter main bearings than later model 327 and 350 engines. The small bearings and slower slip speed between the crankshaft and the bearings make them capable of pretty reliable operation up to around 8K RPM with the right bearings, lightweignt valves, and strong valve springs. A well tuned 283 at high speed sounds like a bunblebee on steroids!
Guitplayer #1458606 07/13/2022 10:52 AM
Thanks Jerry and Doug. Great info!!
~ BD.
drdoug #1458627 07/13/2022 2:48 PM
drdoug That 519 block is what they used in injected Corvettes,the neighbors gave me one of those and it had a 3735236 crankshaft with a drilled snout to hold the harmonic balancer on. Is yours that way ??
Guitplayer #1458629 07/13/2022 2:50 PM
Guitplayer Oh sorry,my question was to you, does your 283 have a drilled snout ??
Guitplayer #1458664 07/13/2022 7:07 PM
Not sure. I am wondering why they moved the motor mounts back some with an added weld on. Either the transmission
shifter to be in the right place or not to shorten the drive shaft.
~ BD.
Guitplayer #1458666 07/13/2022 7:18 PM
That truck originally had a 6 cylinder engine, and instead of buying the correct brackets for the "bird leg" V8 mounts that either bolt or rivet onto the front crossmember, somebody cobbled up some home made brackets. They also swapped bellhousings for one that will bolt to a V8 engine and altered the throttle linkage.
Guitplayer #1458671 07/13/2022 8:17 PM
You can also see where they beat the back of the firewall to fit the
distributor. You are right ..6 bolt wheel = 1/2 ton with a 235.
Thanks so much Jerry!!!!
~ BD.
