| | | Forums66 Topics128,195 Posts1,057,377 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#14584 12/13/2001 2:20 PM | Joined: Dec 2001 Posts: 9 Member | | Member Joined: Dec 2001 Posts: 9 | Hey Guys, I've got a leak (not much, enough to be a PIMA) out of the rear axle hub. Two questions, I have the seal (thanks dad), now i'm wondering, could it be the gasket where the axle bolts to the hub? My dad said that it's the same axle assembly for a one ton that Chevrolet used for 40 years. When installing this rear axle seal, anything to watch out for? Thanks, Ed :confused:
They're more fun shared with others (the trucks that is)
#14585 12/13/2001 6:46 PM | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | The 3/4 & 1 ton used the same axle & housing. There are 2 places that could be leaking: the inner seal between the inside of the hub and the differential housing and the floating axle to outer hub. Usually the inner seal is the one that leaks, and the oil shows up in the inside of the wheel/tire. The outer seal on the outside.
Replacing the inner seal is tricky, but not difficult. When you put the seal in the hub, the spring side of the seal goes toward the outside of the hub, which is the oil side. Also, inspect the differential housing for grooves from the seal. If there are any (very likely) you can buy a sleeve to go over the housing. Cost is about $30 for this part. The seal is about $6.
The hard part is putting the hub on the differential without breaking the sill. Truck mechanics have a dolly to hold the drum/hub. I finally gave in last week and made a plywood tool using two 8"x8" pieces of 1/2" plywood with 2 shelving brackets. Cut one piece with a moon in the side and drilled to attach to the wheel lug bolts, formed a right angle, and set it on my platform jack. Set it to the right height and slid the drum/hub on. What happens is when you install it without support and push the drum/hub on and things arent lined up you damage the seal. If you can disassemble the drum from the hub, you can install the hub first, which is easier.
Now for the outer seal. Mine has aluminum gaskets. Clean all the mating surfaces and the bolt holes. I then use ultra-blue rtv and apply a thin layer to all the mating surfaces and the bolt threads. This is also a good time to buy some new grade 8 lockwashers for the bolts, the originals have lost their spring.
Fred 52 3600 69 C-10
#14586 12/13/2001 6:49 PM | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | One more thing to check is the breather. It should be on top of the differential housing on the driver's side. Remove it (1/8" pipe threads) and thouroughly clean it. If the breather is plugged, you will build up pressure when the oil heats up, and blow out your seals.
#14587 12/14/2001 12:39 AM | Joined: Dec 2001 Posts: 9 Member | | Member Joined: Dec 2001 Posts: 9 | Love this site and the advice. Thanks Fred T for helping. I can't wait to put on ye old mechnics clothes and see what's going on. Thanks, I'll let you know how it goes. Thanks, Ed
