2 members (Rusty Heaps, panic),
51
Mod | | | Forums66 Topics128,009 Posts1,055,293 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2009 Posts: 296 'Bolter | | 'Bolter Joined: Sep 2009 Posts: 296 | I'm thinking I may have a starter failure, but curious as to everyone's input. I had my starter tested 3 years ago when I had my 261 rebuilt and it was in good shape, so I did not have it rebuilt. Yesterday, I drove my truck to the gym, everything working just fine. When I left the gym, I hit the starter and it sounded like the battery was going dead. Slow to turn over and the starter sounded very strange - hard to describe but didn't sound smooth and balanced as it normally does. Tested my battery charge, it was at 85%. Ran my fingers over all of the connections and all looked solid. Hooked the battery back up, hit the starter, and nothing. Dead. Pulled the starter and can't see any sign of damage, starter gear moves back and fourth just fine. (Side note, my truck starts very quickly, I never have to engage the starter for more than about 5 seconds.)
There's a small alternator/generator shop close to my house, I'll run it over tomorrow and have it looked at. Does this sound like a starter failure to you all?
-Patrick 1953 Chevrolet 3100 261 / 4-speed / 4:11 / Commercial Red
| | | | | Joined: Jan 2022 Posts: 2,435 'Bolter | | 'Bolter Joined: Jan 2022 Posts: 2,435 | Among both ends of both battery cable connections, the connections at the starter solenoid if you have one and the starter itself removing the starter for testing is the hardest thing to do. I'd do the others first.
'57 GMC 102, Original 347 V8, HydraMatic, 3.08 rear gear, added A/C, disk front brakes, HEI, AFB carb, '98 Honda Black Currant paint. T-boned and totaled 10/12 '52 GMC 152 Stake Bed, Original 228, SM420, added A/C, HEI, disk front brakes, '67 Chev 3.55 rear gear. Gets used as a real truck.
| | | | | Joined: Mar 2010 Posts: 1,660 Curmudgeon | | Curmudgeon Joined: Mar 2010 Posts: 1,660 | 6 volts? You must have good clean battery cable connections at the battery, at the starter and at the grounding point on the engine/frame.
"Adding CFM to a truck will only help at engine speeds you don't want to use." "I found there was nothing to gain beyond 400 CFM." | | | | | Joined: Sep 2009 Posts: 296 'Bolter | | 'Bolter Joined: Sep 2009 Posts: 296 | 12 volt setup. Battery cables are clean at both ends, battery is 1 year old. Group strap looked ok, but I pulled it off yesterday and hit it and bolts/connections with a wire brush, surfaces very clean now.
| | | | | Joined: Jan 2022 Posts: 2,435 'Bolter | | 'Bolter Joined: Jan 2022 Posts: 2,435 | Assuming the 12 volt setup and you have a voltmeter, I'd start like this with a totally assembled electrical system.
Measure and record the voltage between the battery's positive and negative posts with the key off.
Measure and record the voltage between the battery's positive and negative posts with the key off and the headlights on.
Measure and record the voltage between the battery's positive and negative posts with the key on and the headlights on.
If all 3 measurements above are not at least 12.5 volts the battery is either defective or not charged. Solve that problem before continuing.
Once you've posted those results we can proceed to the next steps.
| | | | | Joined: Sep 2009 Posts: 296 'Bolter | | 'Bolter Joined: Sep 2009 Posts: 296 | Tested, and all readings were above 12.5.
Took my starter in to a small electric shop, pulled the top off, and about a pound of dust and dirt came out and the brushes were frozen. Heavily worn. Pulled the switch off the top of the starter and the electrical contact point was also very worn. The guy was quite surprised it had been working up until last week. Needless to say, it's getting a full rebuild.
| | | | | Joined: Mar 2010 Posts: 1,660 Curmudgeon | | Curmudgeon Joined: Mar 2010 Posts: 1,660 | I believe the brush holder design limits how far the brush can travel down (wear) to prevent armature damage. Black dust will be from the worn brushes. Wear on the electrical contact is normal. I'd say that starter has provided many good cranks in it's long lifetime.
