Fixing the old truck
BUSY BOLTERS
Are you one?
Where is it?? The Shop Area
6 members (Steelonsteel, EchoBravoSierra, Grandpas_48, Ridgeback, klhansen, TooMany2count), 596 guests, and 1 robot.
Topics126,780
Posts1,039,291
Members48,100
Most Online2,175
Jul 21st, 2025
Big Bolt Forum Co-moderator
I was cleaning up my frame and axles for painting and see that the bottom plate for one side of my rear leaf springs is broken. The U-bolts don't look totally healthy either. They look badly rusted where road dirt and moisture have been sitting in the lower plate. Any good source for replacements? U-bolts I am thinking can probably be made up at a suspension shop, but are those plates special to that truck?
1948 Chevy 2-Ton
3B Offline
Hy Super55, if you would like to come out, I'm sure we can find something.
Might have to do that. I have to go into KMS and get some more oxygen for my torch. The impact couldn't budge it. Once I get it off I'll see exactly where I stand.
1948 Chevy 2-Ton
I've had good luck with U Bolts Direct...
https://www.uboltsdirect.com/
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1956 8400 Wrecker w/Holmes 525
1956 9200 Tractor w/Allison Automatic
1952 Willys M38 Army Jeep
1953 Willys M38A1 Fire Jeep
1978 Jeep CJ-5 Navy Jeep
1984 Jeep CJ7
Hughesville, MD
Mike B, Chrome doesn't suggest going to that site because the "certificate" is compromised and out of date. I got slowed down today. Went to go fill up my oxygen tank for my torch and it's out of date. Had to take it in to get re-certified and filled. Another day lost at least. Good thing it looks like we are going to be on a stretch of better weather! It has been so danged wet here basically all spring and into summer.
1948 Chevy 2-Ton
Super55 Go to your spring shop they may have that plate and should be able to make new U-bolts to fit.
Super 55 That U-bolt place probably work with a full size template. Our local shop wont touch those till they get your old ones. The bench in there is 2 inch thick plate,when he steps on the button things BEND. Always aim to be in there to see it !!!
Here's U Bolts Direct contact info.
877-HITCHIT (877-448-2448)
Hours of Operation
Monday - Friday, 8:00 a.m. - 5:00 p.m.
Saturday, 9:00 a.m. - 12:00 p.m.
Sunday, Closed
Address
9 S Peru Street Plattsburgh, NY 12901
E-Mail Address
info@uboltsdirect.com
Mike B smile
Mike Boteler
1984 Jeep CJ7
Hughesville, MD
Super55,
If it helps, I want to support Mike B's suggestion of using Uboltsdirect. I highly recommend this company.
I recently finished a heavy trailer project where I built my own axles. The ubolts I needed where not a standard size, but no problem for Uboltsdirect. They can make you any kind of ubolt you might need.
-David
1953 2-Ton GMC
Used the fire wrench to get the nuts off and free up the U-bolts from the bottom plate. The bolts rusted down from 3/4 to 5/8. One bracket is heavily damaged and the other is just starting to crack!
1948 Chevy 2-Ton
I posted an update. Thanks for the suggestions. I was able to find the u-bolts locally and I figured why not just fix the broken plates. I sometimes just think I have to get new stuff all the time. Funny thing is I follow a guy on Youtube who is a wheel right, https://www.youtube.com/user/EngelsCoachShop/videos and his latest video showed him brazing up some worn out bolts. I thought of that for a minute, but for $100 I got four new bolts. Probably would have spent half of that for some brazing rods and die cutter to chase the threads.
1948 Chevy 2-Ton
Super 55 Spring shop can make new u-bolts,any welding shop should be able to make a copy of those saddle plates out of heavy steel. I made my own for 3100,never made ,well guess I did make them for my 51 6400. Also turned out an aluminum wedge for pinion angle. If you are a weldor make your own !!
Super 55 New bolts are best...our spring shop always stresses to tighten them 3 times,axle torque will loosen them aspecially on big loads.
(Release build 20240826)
Responsive Width:
PHP: 8.3.11 Page Time: 0.032s Queries: 15 (0.029s) Memory: 0.6549 MB (Peak: 0.7685 MB) Data Comp: Zlib Server Time: 2025-09-22 19:43:09 UTC
Valid HTML 5 and Valid CSS
