3 members (Cosmo, LAROKE, 1 invisible), 51 guests, and 2 robots.
Topics128,073
Posts1,055,908
Members48,429
#14580 10/03/2002 2:53 PM
My 49 1/2 ton had no parking brakes when I got it---only remnants of them. My question is how were they activated. One of the rear wheels had an arm attached to the shoe by an eccentric bolt---I assume for adjustment. How does the cable activate this lever? There must be something else missing and the shop manual is not very clear on this. The other side did not even have the lever. HELP! thanks to anyone who has been into these
#14581 10/03/2002 10:42 PM
smile howziit Doc!
when i bought my '56 truck, it had no hand brakes,either.
HOWEVER, perusing through the assembly manuals, the diagrams show a series of rods and levers, which actuate some sort of emergency brake, near the front u-joint, or the tail-end of the trans.
examine your diagrams very carefully.
since my drivetrain was upgraded, alas, i also have no emergency brakes. frown frown frown
Myron
1956 chevy 3100 stepside, Pro-Street stance, mild 454 BBC/350/9"/13" M/T'S, daily driver, aka THE PINK LADY
1957 Bel-Air coupe, 500 HP blown sbc in progress, aka LANI
#14582 10/04/2002 5:42 AM
I can't check under my 51 right now, but if my memory serves me correctly....
there is a big 'bar' that has 2 humps, and streches across the frame, just behind the cab. when you press the foot pedal on the e-brake, it pivots the bar, thus pulling the e-brake cable. mine was frozen up tighter than a frog's a** when i got it, and it took quite a bit of persuation to get it to work again. hope this helps.....
Build 'em to Drive 'em
#14583 10/04/2002 6:52 AM
Ok, my memory is fogged by the rain we're having here, and my shop manual is doing a good job of hiding, but I will tell you what my '50 1/2 ton is like. This is the 'huck' type brake with the wheel cylinders that have the adjustment on them. The rear drum brakes have a cable that goes through the a hole in the backing plate at the bottom. It attaches to a nearly vertical arm in the brake that runs from down near the bottom of the brake up to a pivot point that the eccentric is attached to on the shoe (I'm a bit foggy here), and it engages a slot in the pushrod which connects to the other shoe horizontally. The other end of the cable attaches to the frame where it is connected by turnbuckles to the big pivot rod at the front of the bed on the frame. That connects to the pedal assembly in the cab.
If you are missing the pieces I'm sure mothertrucker can set you up. What you should really do is get a reprint of the original shop manual (see links in vendor section), which has nice pictures and tells you how to adjust the eccentric and the brakes. It's only about $25 and it really is a very good manual.
I had to replace my cables and they are hard to find. Fortunately I had my originals and I had my local speedometer shop make me some really good ones that are sheathed with rubber for $40 each. They are smooth and nice. The brakes work great now.
Paint & Body Shop moderator
