| | | Forums66 Topics128,021 Posts1,055,348 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2019 Posts: 6 'Bolter | | 'Bolter Joined: Aug 2019 Posts: 6 | I have a 1950 Chevy 3600. It has all original drive train, 216 and 4 speed tranns. My question is regarding the speedometer. I could tell it was reading slow, so I checked it against GPS. It seems that it is running about 12-15 mph slow. I'm wondering how this can be. I would get if it was running fast because someone maybe changed the gears in the differential, but this thing is geared really slow and I doubt that it could be geared any slower. As far as I can tell the differential is all original. The shop manual says it is 4.56 gears and I believe it. I'm afraid to take it over about 50mph (37 or so by the speedometer) as the engine is running pretty fast at that speed.
Any ideas? | | | | | Joined: Apr 2005 Posts: 7,440 Bolter | | Bolter Joined: Apr 2005 Posts: 7,440 | 50 mph is about the best you can expect from a stock setup. Try removing the mechanical cable and lubricating it.
| | | | | Joined: Aug 2018 Posts: 1,004 'Bolter | | 'Bolter Joined: Aug 2018 Posts: 1,004 | Perhaps Your speedometer magnets are weak
consider that the cable doesn’t lose any turns even if it’s dry, One turn in equals one turn out the other end If turns build up inside the cable that will be a very short lived situation as the cable will quickly snap clean off
So cable friction can’t slow a speedometer a dry cable can momentarily stick and cause irrational jumping so lubricating it is a good idea But to get your missing mphs you will need to service the speedometer There are a few discussion on here about how to do that Search the old posts -s | | |
