8 members (Otto Skorzeny, Steelonsteel, Gdads51, J Lucas, Peggy M, dt235sd, walter74, klhansen), 127 guests, and 3 robots.
Topics128,036
Posts1,055,454
Members48,422
#1458107 07/09/2022 11:46 PM
I have a 1950 Chevy 3600. It has all original drive train, 216 and 4 speed tranns. My question is regarding the speedometer. I could tell it was reading slow, so I checked it against GPS. It seems that it is running about 12-15 mph slow. I'm wondering how this can be. I would get if it was running fast because someone maybe changed the gears in the differential, but this thing is geared really slow and I doubt that it could be geared any slower. As far as I can tell the differential is all original. The shop manual says it is 4.56 gears and I believe it. I'm afraid to take it over about 50mph (37 or so by the speedometer) as the engine is running pretty fast at that speed.
Any ideas?
Chuck A #1458109 07/09/2022 11:53 PM
50 mph is about the best you can expect from a stock setup. Try removing the mechanical cable and lubricating it.
Chuck A #1458115 07/10/2022 12:20 AM
2 Offline
Perhaps Your speedometer magnets are weak
consider that the cable doesn’t lose any turns even if it’s dry,
One turn in equals one turn out the other end
If turns build up inside the cable that will be a very short lived situation as the cable will quickly snap clean off
So cable friction can’t slow a speedometer
a dry cable can momentarily stick and cause irrational jumping so lubricating it is a good idea
But to get your missing mphs you will need to service the speedometer
There are a few discussion on here about how to do that
Search the old posts
-s
