6 members (Stan 58, 46 Texaco, RoadsScholar, Otto Skorzeny, Peggy M, 1 invisible), 127 guests, and 2 robots.
Topics128,083
Posts1,055,967
Members48,430
Page 1 of 5 1 2 3 4 5
#1434070 12/19/2021 1:51 PM
I purchased a 1949 (1950) Chevy 3600 truck that appears to be in original configuration with an in-line 6-cylinder engine and 4 speed floor shift transmission. The title says it is a 1949 but the serial number decoding indicates it is actually a 1950. The shock configuration (tubular type) appears to confirm the 1950 rather than 1949 vintage (see photos attached). The overall thought is to have a great looking functional truck that I could drive and take to car shows.
I am in process of disassembly to identify what needs work (primarily body rust repair in the typical locations) and developing my project plans. The original concept was to convert the drivetrain to utilize a SBC 383, coupled to a NV3500 transmission, with a revised ratio (4.11) in the original rear axle, update the brakes to disk front and rear, but retain the original suspension and axle mounting/springs with the wheels and tires updated to more recent technology. An alternative concept is to retain the original 6-cylinder engine and transmission and basically restore more or less to original. I would probably still upgrade the front, and possibly rear brakes to disk as well as update the wheels and tires to more recent technology.
I suspect that there a number of opinions regarding the two concept paths and would appreciate input before I decide which path to take.
1949/50 3600 Project
Follow in Project Journals
WICruiser #1434326 12/21/2021 10:50 PM
Plan for bed sides: determine location of existing box side angle strips, remove original strips, repair box sides as needed, purchase and install new box side angle strips.
Plan for cab: establish correct cab to frame spacing with front and rear cab mounting points secured, remove rusted floor sections and replace with patch panels (one area at a time), then remove cab from frame to remove rusted cab corners and replace with patch panels. More information in Sheet Metal Shop area.
Engine ID reported to be a 235 made between 1957 and 1962 for the passenger cars with 3-speed transmissions. T = Tonawanda Engine Plant; 8 = Month (August); 06 = Day; A = Regular 235 for passenger cars with 3-speed transmission. Subsequent engine block (3737004) casting and cylinder head (3866848) cast numbers determined. Also located tag that indicates it is bored 0.060 oversize, have 0.010 undersize rod journals, and I believe 0.010 undersize crank journals. Sounds like it is not worth keeping but may be able to sell all or parts. More information in Engine Shop Area.
Conflicted regarding powertrain direction.
I have a NV3500 from a 1995 GMC Sierra 4WD (with the transfer case) but adaption to 2WD is a challenge. Considering using the NV3500 with an adapter to the original mid-drive shaft (torque tube) but requires parts and machining to end up with a two-piece drive shaft that may not be ideal. Locating a manual transmission with OD for a 2WD truck application appears to be challenging and possibly expensive. Clutch actuation from the pedal to the throw out bearing will also be challenging.
Automatic transmissions seem to be readily available but newer versions are electronic which raises the question of doing a complete LS engine and transmission installation rather than using the 1991 350/383 engine option. If I go the LS route, I could purchase either an engine/transmission combination with the wiring and ECUs but programing the ECUs for the existing rear axle ratio etc. would require something I don’t know how to do. I could also consider purchasing a wrecked truck to obtain the required LS engine/transmission parts and possibly some additional items such as rear axle, seats, steering column, etc.
Anyone out there that has done an LS swap with electronic automatic transmission that could provide insight regarding fit issues and ECU programming issues would be appreciated.
Fox Offline
PM BarnFind49
1970 Chevrolet C10
1950 Chevrolet 1-Ton Dually
"Ole Red Girl"
More pictures here
Parts trucks-
Located an NV3500 2wd transmission and plan to purchase/pick up 1/23/2022.
The engine machine shop has confirmed that my 350 block is okay, next step is to determine what block machining is required.
After decisions are made about the bore size need to work on ordering engine parts (including decision regarding 350 or 383 displacement). First blush is to go with the 383 but depending on heads and cam the increased compression ratio could be a concern (would like to retain regular gas).
Appears my driveline direction is taking shape with the 350/383 SBC engine, NV3500 manual transmission, etc. The existing (original) rear axle ratio will result in higher engine rpm at 60 mph cruise than optimum but with taller tires should be acceptable.
It has been cold here in WI so I have generally been limited to working on fenders, etc. that I can easily carry from the back shed where the truck is located to a heated garage. Primarily working on rust repair and banging out some of the larger dents. Overall the fenders are in good shape but that doesn't mean that there aren't rust issues to be resolved, primarily at the bottom edges, and some cracks.
When the weather has allowed I have started working on bracing my door openings prior to removal/replacement of floor sections and cowl panels. I have ordered and received patch panels for the floor, inner and outer cowl, fuel filler opening, and rear cab corners. My plan remains to do as much of the floor and cowl repair as possible with the cab mounted to the frame, then remove the cab to complete the cab work and also work on the frame. The frame appears to be in good condition but with all the grease and grim accumulated over the years I will not really know until I can get it cleaned up. I did find the driver's side rear running board bracket is broken below the top mounting rivets so I need to decide if I am going to repair it in place or remove it for repair.
I picked up a set of seats from a 1999 Chevy truck that include the integrated seat belts. The front and two sides of the original seat riser were previously removed. Setting the seats in roughly their intended position I think I want to raise the seats roughly 1 1/2 inches above the existing cab floor with their seat tracks against the remaining original rear seat riser. with approximately 6" between the seats. I am developing a plan for a combination seat riser/floor reinforcement structure but continuing to work through the details to ensure both structure and safety.
We have not had the best luck with the NV 3500 (or T5) trans in anything with a lot of torque and/or big rubber. Fine for cruising or showing but iffy if hammered. As far as clutch actuation is concerned the factory set up from the 60-62 Chevy pickup hydraulic system can be used or from early 90's Chevy pickups that came with the NV 3500. We used the McCloed after market hydraulic TO bearing and plumbed it in. Concerning overdrive transmissions one can still pickup the old BW 3sp OD unit at swap meets for $250-$500 and it is as strong as the T5 or 3500 and gives a final gear of 3.05 with a 4.56 or 2.88 with the 4.11. Just make sure the solenoid is good before purchase. I came to Texas 60 years ago from Minnesota and can relate to wintertime difficulties in working on old rides. First winter in Texas found out it's WAY easier to shovel sunshine.
Evan
Coilover, thanks for your input regarding the transmission. I realize that the NV3500 is somewhat limited regarding torque capacity but I have had some experience with it behind a SBC in another project and I think it should be okay for my plans for the truck. I will look for the early 90's factory clutch setup that you mentioned.
Continuing to work on patching minor rust, crack issues on sheet metal parts that I can move into my heated shop area. Considering the truck looked pretty solid as I dig into it every part seems to have some rust or crack that needs to be repaired. At least I can continue to work on the project a few hours each day and feel like it's not just waiting for warmer weather.
I ordered the rotating assembly parts required to build a 383 SBC and the machine shop is machining the block as required to clear the rods. I order dished pistons to keep the compression ratio in the 9:1 range so that I have a chance to run regular fuel rather than premium but still have not decided on cylinder heads or cam for the engine build. Unfortunately the parts I ordered are not expected to be available until May so the engine build will probably be conflicting with the cab, frame, etc. work I need to due during the warmer months.
I am working on the cab when the weather cooperates (not often) but have braced the door openings and made some preliminary plans regarding how much of the floor, firewall, inner and outer cowl panels, etc. to cut out.
Unfortunately the project is at a stage where I have a thousand ideas of things I need to consider and no ability to actually move forward on them because they are dependent on getting the cab work done enough to remove the cab from the frame, getting the frame cleaned and painted, etc. I probably need to create a detailed action plan to lay out the sequence of things that need to be done so that I don't loose track of things given the large number of sub-project activities that interact.
Started the cab patch panel work today by cutting out the floor, firewall, inner, and outer cowl panels on the passenger side. More details in the body and paint section.
I picked up the cylinder block from the machine shop and dropped off the original cylinder heads for cleaning, valve job, etc. Looking at options regarding accessory mounting (see Hi-Pro section) so that when I get the parts to start engine assembly I know what water pump rotation and length to buy.
WICruiser #1447094 04/05/2022 12:13 PM
Still plugging along on the cab repair and appear to have decided on a path forward for the passenger side. Still a fair amount of work to be done but progress is being made.
I picked up the cylinder heads from the machine shop and am now waiting for the rotating assembly parts (expected in early May) to move forward with the engine build.
WICruiser #1447224 04/06/2022 12:36 PM
AD Addict & Tinkerer
We bolters love pictures! You know the saying, “a picture is worth a thousand words”!
Phil
Project Journals
Stovebolt Gallery Forum
WICruiser #1448682 04/19/2022 12:04 PM
I welded in the panels on the passenger side. I still need to do some work but decided to move on to the driver's side repairs.
For more details and pictures please refer to the Body and Paint Shop Area.
WICruiser #1448807 04/20/2022 11:48 AM
I understand that the preferenc is to post pictures etc. regarding project progress here rather than the Body and Paint Shop Area so in the future I will be posting more here and less in the various project sections.
WICruiser #1449207 04/24/2022 12:25 PM
I am working on the driver's side floor and cowl panels now and have them screwed in place. Other than the fit issues between the floor and the inner cowl and the 1/2" gap between the driver's and passenger side floor panels it is going fairly well. I fit checked the door and after a self induced problem was resolved the fit looks pretty good so I plan to continue my efforts to get the floor and cowl panels weled in place (probably several steps and another door fit check along the way).
WICruiser #1449872 04/29/2022 12:08 PM
Driver's side floor and cowl panels screwed in place, door fit confirmed. Next step is to fill all the "extra" holes for features not being used (parking brake, clutch & brake pedal, etc.), add filler piece for center gap and upper left corner of floor/firewall.
Once I have the floor and cowl panels in place I plan to move on to fabrication of the seat riser/mounting bracket. th eoriginal seat riser had been removed (mostly) by someone prior and the remaining portion (rear) is modified. My plan is to tie the rear of the new seat mounting braket to the remaining portion and also the floor and door latch pillars.
WICruiser #1450521 05/04/2022 12:01 PM
I have the initial welding completed for the driver's side floor and cowl panels. I closed up most of the holes in the floor that I do not anticipate being used prior to installation.
I started on my seat mounting bracket and checked the seat position relative to the steering column firewall hole/dash mounting and foot position related to the floor and all seems good. The seats are from a 99 Silverado with integrated seat belts and the seat bracket will provide 1 1/2 inch rise to get the seat cushion approximately at the factory seat height. The seat mounting bracket will be attached to the floor and the rear original seat riser (only remaining part) with the seat mounting bolts going through the bracket and floor to further secure everything. The front mounting bolts will require the bracket to be shimmed from the floot due to the recess formed in the floor pan but the intent is for the final bolt column to be solid to avoid any deflection of the floor pan related to the mounting bolts.
WICruiser #1451213 05/10/2022 12:25 PM
I have the seat frame built and placed, bolted using seat mounting bolts (6 of 8). I plan to paint the bottom side of the frame and the floor area that will be covered prior to welding in the frame. The plan is to weld the frame to the remaining original seat riser at the rear, the door latch posts, as well as the floor at the front edge of both cross angles. The inner front seat mounting bolt area is high enough above the floor that nuts were welding into the frame rather than going through the floor. The rear seat mounting bolts required a single washer on the bottom of the frame to make up for the thickness of the cross angle, but the outer front mounting bolt locations required a stack of 6 washers to be welded in place as a spacer to make up the gap to the floor. All bolts that go through the floor are being secured with large, thick fender washers to spread the load on the floor. I had considered welding the washers to the floor but have decided against that due to concern that the welds would cause more harm than good.
Once the seat frame is welded in place I plan to remove the cab from the frame to allow the bottom side floor and cowl panel welding etc. to the cab as well as work on the frame.
WICruiser #1451701 05/15/2022 12:07 PM
I got the seat frame welded in place and proceeded to pull the cab off the frame. I used a cherry picker (engine hoist) to lift the cab from the two new front outside mouting bolt locations which seemed to be fine until I got the cab clear of the frame and the lack of a third lift point allowed the cab to rotate. I ws able to get the cab onto a dolly I made with a pallet but then proceeded to tip the cab on its back to allow finishing the welding of the floor and cowl panels. Once the front area work is complete I plan to flip it onto the firewall to allow work on the rear cab corner area that also needs attention.
I plan to pressure wash the frame and remove anything (pedals, brake lines, etc.) prior to sand blasting and painting the frame. I do need to resolve a front brake issue as it generally rolls free but occasionaly the brake engages and prevents the wheel from rotating.
Biggest challenge now with the cab off the frame and engine build parts expected in the near future will be scheduling time to work on all three fronts (frame, cab, and engine) in the most efficient way. Ideally I will be able to do an initial engine/transmission fit check to determine what I need to do about the original rear engine mount before I get too far into the frame painting portion of the project. To faciliate the confirmation of engine/transmission vs. cab I may need to be able to temporarily put the cab back on the frame so I need to develop a better lifting plan that keeps the cab level next time.
WICruiser #1451703 05/15/2022 12:31 PM
A 4x4 attached to the end of the engine lift boom thru both door opening with doors off, works great for lifting the cab. You’ll have to lift and reset the 4x4 a couple of times to find the balance point. Once balanced, secure it with ratchet straps.
Here is a link on how one member, ‘klhansen’ did it.
https://www.stovebolt.com/ubbthread...or-not-1950-five-window.html#Post1394371
Phil
Project Journals
Phak1, thanks for the additional option for lifting the cab.
I worked on the cab a little but spent the majority of my time yesterday on the chassis. Pressure washed to remove most of the years of accumulated debris, removed the brake lines, pedal assembly and related bracket, parking brake cross shaft and related parts, front and rear bumpers, shocks, and right front brake shoes (spring was broken resulting in periodic brake lock up).
I also recieved my order (Sunday delivery, Yeah) from Jim Carter so I can work on engine mtg and related transmission mtg bracket location/install.
WICruiser #1452110 05/19/2022 12:27 PM
I have tack welded the engine mounts in place on the frame and then used the engine block/transmission combination to locate the new transmission support. The original rear engine mounting cross member interferred with the transmission housing, primarily the portion housing the slave cylinder/clutch actuator so I removed the center portion leaving the sides that reinforce the frame in the area of the front axle spring mount.
The new transmission cross member was located for/aft by the engine mount locations dictating the engine/transmission location and then the vertical position was determined to give the engine block a 3-4 degree drop to the rear. The transmission cross member brackets needed to be oriented with the longer side horizontal resulting in significant angle disparity between the brackets and the frame, due to the frame taper. I reduced the cross tube engagement with the side brakets to less than 1" to provide more angle flexability to get the brackets tight against the frame. The brakcets needed to be located approx. 2 1/4" above the lower frame flange to achieve the desired engine angle. With all in place the bracket mounting bolt holes were drilled and the brackets mounted. The center section location was adjusted to center the transmission output shaft side to side and then the center section was tack welded to both brackets.
I have measurements for the cab relative to the frame from before the cab was removed and confirmed that the vertical firewall should be located approx. at the rear of the engine block. As I do not have the heads, intake, or distributor in place it's a little hard to confirm clearances but I am fairly confident it should be good. I also checked the shifter location relative to the opening in the cab floor and that looks like it should be good.
Next step is to fully weld in the engine mounts and fully weld the transmisison mount tubes.
I am considering fabricating a means to reinstall the removed original cross member as a bolt in but it will need to be located further back and probably a little lower than the original location.
WICruiser #1452706 05/25/2022 12:09 PM
I determined that the removed cross member needed to be shifter rearward about the width of the channel and I increased vertical clearance by dropping it down approx. 1/2". Tacked in place with the bolt in plates it provides good clearance to the transmission housing where the integrated clutch slave cylinder is located as well as the bottom of the transmission.
In parrallel I am working on installing the rear cab corner patch panels. The driver's side I needed to fabricate a replacment inner panel in addition to installing the outer patch panel. I still have some work to do but ready to move on to the passenger side.
I installed the passenger side rear cab corner patch panel, the inner panel was okay. I also installed the patch panel for the fuel filler in the cab (I plan to use a rear frame mounted fuel tank).
I painted the underside of the cab with an epoxy primer, next step is to apply seam sealer, and body filler where needed.
I purchased and did a preliminary installation of a 15 gallon fuel tank to determine if any frame modifications would be required prior to having the frame blasted, primed, and painted.
The tank is from Tanks Inc. (USPT-HG) and did not require any modifications to the frame cross members but I did add two straps across the top so that when the tank support straps are installed there is something other than the bed cross member to restrict the tank moving up. I split a piece of heater hose and slipped it over the lower rear frame cross member to asct as a cushion. I plan to cut it down to be pieces that are slightly wider than the tank support straps to minimize the potential to trap dirt and moisture. The tank straps will come from the forward cross angle to the rear frame cross member.
The tank is short enough fore-aft that it fit up into the frame with the front cross angel in place. With the tank flange tight up against the rear cross member lower flange (actually the hose cushion) the top of the tank has clearance to the bed cross member that is located approximately mid tank. Note that the cross member in the pictures is the original as I have not purchased the new bed cross sills yet).
The tank is narrow enough that I anticipate having room to run dual exhaust pipes out the back of the truck.
The tank does still hang down below the frame but I don't think it will be objectionable visually and it is higher than the lower shock mounting brackets as well as the differential center section.
The tank has multiple filler options but I plan to use the option that angles out of the passenger side rear corner that has enough up slope to clear the frame with the tank centnered side-to-side. I plan to run the filler into the passenger side rear fender area. I have not determined which filler style I will use yet but anticipate I will use a piece of exhaust tubing (not sure if it will be straight or require a bend to clear the bed floor at the bed side) and associated rubber hose connections to connect the outside fill location to the tank.
The sending unit opening is forward of the bed cross sill so no interfernce concerns and I am running a carburetor with an in-line fuel pump so the top filler/pump opendings can be closed off with the plates provided. If someone wants to install an in-tank pump at some point in the future the bed cross sill may cause interference but I believe the easiest solution would probably be to lower the tank slightly.
I painted the underside of the cab with rustoleum rattle can gloss black.
I am preparing the frame for blasting and painting, still trying to decide if I should leave the axles in place or remove).
I removed the axles (with springs attached) and took the frame to be blasted and painted.
I decided I really wanted to confirm the rear axle and I could not find any markings that would confirm the ratio so I removed the rear cover, still no information stamped into the ring gear so I just counted the ring gear teeth - got 32 so that aligns with the expected 4.57:1 axle expected for the 1949/50 3600 model designation.
I finally received the parts for my engine build (383 from a 1991 TBI 350) and am slowing working on prep of the block etc. for the assembly process.
WICruiser #1458048 07/09/2022 12:32 PM
I have made progress on finishing the rear cab corner patches and the fuel tank filler patch. I am trying to decide if this is the time to strip and prime the reat of the back and the outside top of the cab.
I need to get busy on the engine build. My plan is to have the engine and transmission together and installed in the frame before I put the cab back on, but plans can change.
WICruiser #1460465 07/28/2022 12:16 PM
I have the engine build completed to the point of being able to install the transmission and soon install the combined unit into the truck frame. I still need to decide if I am keeping the original rocker covers or replacing them as well as a lot of plumbing related to the intake manifold but that will all be sorted out in time.
I received the frame back from the paint shop. It looks great (ignore the water spots in the attached photo). Now I need to reinstall the axles (less brake parts) to make the chassis mobile. Once the axles are in place I plan to install the engine-transmission then the cab to determine if everything clears or modifications are required.
WICruiser #1460619 07/29/2022 12:37 PM
Installed the axles, although I do not have the tie rod in place, so I have independent front wheel steering at the moment.
Installed the engine and transmission combination.
I have some work to do on the cab but next big step is going to be installing the cab onto the frame to determine if any modifications are required to clear the engine/transmission.
WICruiser #1460991 08/01/2022 12:29 PM
I installed the cab temporarily to check clearances and found that I needed ot modify the transmission clearance for the bell housing (NV3500) area. With the modifications made the cab sitting in the correct location as defined by the front cab mounting bolts there is good distributor clearance to the firewall.
Need to get the cab exterior repairs completed so that I can get the cab installed.
Continuing to work on cab cleaning/priming prior to installation on the frame.
Recieved and attempted to install front disk brake conversion kit. The kit is listed for 55-59 but is suppose to work on '50 spindles with slight enlargement of the bracket mounting holes. However, the bracket notch is not wide enough to seat properly onto the machined surface of the spindle. Given that I will need to machine the spindle to clear in addition to enlarging the bolt holes I plan to remove the spindles, have them machined as required and reinstall. I will take advantage of the opportunity to inspect the king pins and related bushings (they seem good).
WICruiser #1462117 08/10/2022 12:22 PM
Installed the front disk brake conversion lit. The interference problem previously mentioned was resolved with the spacers included in the kit that secure the bracket away from the spindle surface. Unfortunately the kit does not include any instructions but with the spacers installed the bracket mounting surface for the caliper is parrallel to the rotor surface. The spindles needed to have the upper mounting holes enlarged from 7/16 to 1/2" which doesn't sound like much except the spindles are hardened so they can not be drilled.
I did remove the king pins and the pins and bushings all look good, but now I need to find a source for the caps that go into the axle above and below the pin to prevent the grease from leaking out and letting dirt in.
WICruiser #1462947 08/17/2022 12:18 PM
Installed the cab on to the frame and removed the temporary braces from the door openings. The cab mounts are redone with new rubber bushings in the rear and isolator pads in the front.
I still have a lot of work to do on the cab but this is a giant step in the project.
WICruiser #1462951 08/17/2022 12:45 PM
Looking great! It is a milestone!
Phil
Project Journals
I have been working on the adaption of the S10 brake booster/master and related pedal backet for both the clutch and brake (see HighPro forum for details) utilizing a C1500/2500 clutch master cylinder. All the fluid addition related access points will now be under the hood and easily accessable.
I basically have the system worked out and while I need to make a few tweaks I think I have the system basics in place.
With those details sorted out I can get back to finishing up the cab interior body work and get the underside of the dash and floor area painted.
I am also making progress on the 14-bolt rear axle swap but need to get spring perches and U-bolts before I go much further. In the mean time the original Eaton H052 axle is in place to keep the chassis mobile.
Taking a road trip so no progress expected for the next couple of weeks but generally I am trying to work on some aspect of the project every day to keep things moving forward.
WICruiser #1467026 09/18/2022 12:59 PM
I have what I believe is the final version of the pedal bracket ready for paint.
Back to working on the interior of the cab to finish the patch panel areas and prep for priming/painting.
The radio knob holes have been butchered over the years and I am not planning to install a radio so I am considering plutting in a patch panel that will fix the mounting holes and close the larger opening. However I may just repair the knob holes to preserve the radio opening for a potential future installation.
WICruiser #1467682 09/22/2022 12:27 PM
I decided to go with Rams Horn exhaust manifolds, they look pretty good as far as frame clearance goes. I will need to do some work on spark plug wire routing. Next up is determining the steering - move the original out to clear the exhaust or convert to a newer power steering gear box.
I painted the underside of the dash and the interior firewall area. Not pretty but it will eventually be covered with sound adsorbing material so not a concern.
Installed the pedal assembly with the brake booster/master cylinder and the clutch master cylinder.
I need to keep working on the cab to get any painting/priming work done before cold weather sets in.
Ordered the parts for the 14-bolt axle conversion also.
I am hoping to have the cab primed, steering resolved, and rear axle swap completed before I relocate the chassis to the unheated back shed for the winter.
I am in process of relocating the standard steering gear outward to clear the exhaust manifolds and fabricating a new drag link to be mounted inboard of the pitman arm to provide something close to the original steering geometry.
I have the 14-bolt rear axle in place and it is clear now why I needed to relocate the brake backing plates outward and use shallower brake drums as the U-bolt to frame clearance is still pretty close. I am still working on the lower shock mounting brackets to finish the 14-bolt installation.
I cleaned and primed the cab door openings and rocker panels and treated the interior cab with POR-15.
I am working on a revised transmission cover to deal with the NV3500 transmission shifter location and the firewall/floor modificatoins required for transmission clearance.
WICruiser #1471854 10/21/2022 12:37 PM
I transferred the lower shock mounting brackets from the original HO axle to the 14-bolt axle.
I installed the fuel tank, although I need to replace the hardware before it is complete. The filler tube will be sorted out when I get the bed supports and sides ready to be installed (a ways off) with the filler expected to be in the rear fender.
Moderated by  Phak1
