| | | Forums66 Topics128,042 Posts1,055,595 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2005 Posts: 305 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 305 | i have just returned home from buying a 42 1 1/2 ton truck have know idea how to get it home yet but the cab is solid as a rock may part it out if i use the cab on my 1/2 ton pickup email me if you need parts
ya I know a few rednecks.Thay all drive chevys to, Proud member of the Old Dominion Stovebolt Society AND A MARINE trucks range from 1942 1/2 ton to 1965 fire engine
| | | | | Joined: Mar 2005 Posts: 284 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 284 | I am still looking for the filler panel that goes between the fenders below the grille.Even if you have one that is half rusted out or all beat up I would be interested as I would fabricate a new one.Its just that when I got my 42 there wasn't one there. | | | | | Joined: Dec 2003 Posts: 2,733 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 2,733 | Hi Hillbilly..why don't you place a request on the Hauling Board (located toward the bottom of the Swap Meet section) to find someone who can help you get your baby home? It's a new feature that many haven't found yet. Check it out. | | | | | Joined: Jan 2005 Posts: 305 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 305 | i only need to move it 15 miles think i found a person with a big rollback hope to have it home tomarrow night
| | | | | Joined: Feb 2000 Posts: 587 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 587 | These trucks aren't heavy, any standard tow truck should be able to handle it, specially easy if no bed on it. I myself have a tow bar. I remove front bumpers, bolt on the tow bar to frame rail ends. Can pull with 3/4 or bigger truck and it follows/steers w/out a helper in the pulled truck. It has to roll and hold air in tires of course.
G.L. Grumpy's Old Iron Ranch Huntington, IN 46750
MM R tractor, Speedex and Power King tractors
| | | | | Joined: Jan 2001 Posts: 332 Big Bolt Shop Curmudgeon | | Big Bolt Shop Curmudgeon Joined: Jan 2001 Posts: 332 | Apart, if you want to really get us frothin' at the mouth, give us a pitcher. Ya know, pitchers is worth more words than you can shake a stick at.
Drivin' down a 2 lane country road in a stovebolt.....cowboy, it don't get no better than this!
1946 1-1/2 ton Chevy "Ol Blue", or "THE BIG 'UN"
