3 members (Southerntruck, Hanks custodian, KEVINSKI), 123 guests, and 1 robot.
Topics128,162
Posts1,056,933
Members48,458
#1457716 07/06/2022 8:42 PM
back yard wrench turner
I have a 55 GMC 3 speed trans in my truck. It started jumping out of 3rd gear the other day. It hasn't been doing this until now.
What do I need to look at to make a determination how to repair?
Wayne
1938 1-Ton Farm Truck
Stovebolt Gallery Forums
1989 Silverado
1996 Mustang GT convertible
Unfortunately it's a fairly common event with 3 speed transmissions both in the early transmissions with a torque tube and the later open driveline version. I would start with the shift linkage and make sure it fully engages and doesn't have a lot of slop.
Next check the universal joint which can cause a vibration effect and cause it to jump out of gear. It could possibly be a worn 2-3 shift fork and/or weak springs on the shift fork detent balls. Worn bearings can also cause an issue similar to the u-joint problem. And of course the good old syncronizer assembly which is a common wear part.
Or it could be a combination of all of the above.
Fred
Could be the input shaft pilot bearing in the flywheel also. A worn one will allow the input shaft to be out of alignment and at a slight angle to the mainshaft which can cause the engaging clutch teeth to walk out of engagement.
H Online: Content
Do't forget to check the transmission case to bellhousing bolts for tightness. I've cured several jumping out of gear problems by simply tightening the bellhouding bolts.
I remember years ago , having this problem. It is one of the most annoying problems that one can have.!!
1951 1 Ton Completed
You don't say if it is a 55.1 or a 55.2. Either way there is a good chance the syncro drum is worn and no new ones offered. It should have an open driveshaft so it is not a hard swap to put in a fully synchronized 67 or newer 3sp trans.
Evan
Curmudgeon
Curmudgeon
Wayne is this the same transmission with floor mount shifter from you previous post?
https://www.stovebolt.com/ubbthreads/ubbthreads.php/topics/765630/1.html
Yes it's the same. I'm using a Hurst shifter with it
Wayne
1989 Silverado
Curmudgeon
Curmudgeon
Unknown used transmissions can used transmission problems. Things you get into resurrecting old trucks.
#1 thing to check, does the transmission have lubricant or has it all leaked out?
If I remember correctly the 3 speed can have wear issues with the shift shaft bushings and synchronizers.
It wouldn't hurt to check the previous mentions and external things before going internal.
