2 members (JW51, Phak1), 92 guests, and 3 robots.
Topics128,081
Posts1,056,321
Members48,442
Is is possible for there to be a connection between fuel pump failure and the cam shaft? I am talking about the mechanical parts not the diaphragm?
1946 1-ton Panel
1952 1-ton Comml. W/Grain Body
Yes, the cam lobe can wear enough to not pump the fuel pump, or the pump arm can wear out or even come apart.
Moderator, Electrical Bay
It used to happen commonly on Plymouth 383 engines made in the late 60s, but it was the push rod that sat between the cam and fuel pump that frequently failed. The worst part was the rod would mushroom on top and then it was very hard to remove. Even if it mushroomed just a tiny bit (which usually didn't happen on that sad engine). People finally started cutting a recess on both ends of the replacement push rods. I have not seen this happen on Stovebolt engines, but I have seen pump arms fail...on aftermarket pumps. Good luck.
~ Jon
Just don't get tempted to stick a finger into that hole and crank the engine to see if the lobe is still there- - - - -use a bright flashlight and an inspection mirror or maybe a magnetic dial indicator to check the cam lobe!
"Why not?" asked Stubby
Thanks all, I replaced the fuel pump and things appear to work great. I am going to change oil to make sure it didn't get too contaminated. The old pump worked, but there was the elusive grey dust starting to form in addition to leaking like a sieve. I think that means something is wearing and the case is deteriorating.
1946 1-ton Panel
