3 members (RLB, Oswald, GRNHydra), 86 guests, and 2 robots.
Topics128,030
Posts1,055,430
Members48,422
#1457131 07/02/2022 11:58 AM
I
I Offline
working on starter for inline 6 59 apache, still has stomp foot solenoid. I have no manuals or pics, sorry. I am in need of original style bolt which goes through the arm which drops down into starter housing and activates the staring gear drive. Same arm that pushes against solenoid button. Does anyone know where to source one of these unique bolts? Any help greatly appreciated.
53 chevy 3100
IHPWR #1457303 07/03/2022 12:04 PM
You may have to take the part to a machine shop and have one made.
Harold
Harold
I believe that's a shoulder bolt. "Standard" size ones are available from places like McMaster Carr, if you can determine what the dimensions are. I'd be willing to remove the bolt from my starter to measure it for you if you need dimensions.
[on edit] I pulled mine off and measured it.
The shoulder is 1/2" nominal diameter, 1/4" from head to end of shoulder, and overall length of 1". The threads are 3/8"-18. Has a round head, but anything would work.
Curmudgeon
Curmudgeon
Listed under section 2.108
The arm (starter shift lever, GM 1885814)
Bolt (stud, 3/8-16 X 1/4 shoulder, length-5/8, flat head GM 1885817)
http://www.gmpartswiki.com/getpage?pageid=20248
Do some measuring on your shift lever. There are other starters listed. Have to figure out which parts are correct.
IHPWR #1457378 07/03/2022 10:28 PM
I
I Offline
thank you both, very appreciative.
53 chevy 3100
