| | | Forums66 Topics128,281 Posts1,058,472 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2020 Posts: 68 'Bolter | | 'Bolter Joined: Jan 2020 Posts: 68 | Does anyone know the correct thread size and pitch for the crankshaft of a 235?
Mike
| | | | | Joined: Feb 2004 Posts: 29,951 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,951 | I used to sell a drill/tap/threading kit to make a 7/16-20 bolt go into a stovebolt crankshaft, the same as the one used on later model small block V8's. There was no bolt at all on any stovebolt sixes from the factory. They were all press fit only on the balancers. The center bolt and heavy flat washer for a SBC is usually available at a local parts store's "help" section, and those are 7/16-20. Jerry
| | | | | Joined: Jan 2020 Posts: 68 'Bolter | | 'Bolter Joined: Jan 2020 Posts: 68 | Jerry, thanks, mine has a hole in the center, maybe added later. The threads are stripped out and I am trying to find the correct tap, it looks larger than a 7/16. Do you know the best way to install the harmonic balancer without using the hole to anchor to?
Mike
Mike
