0 members (), 70 guests, and 4 robots.
Topics128,179
Posts1,057,159
Members48,465
TomStenger533600
TomStenger533600
Does anyone know - if it's possible- for me to obtain just the bottom flange of the carburetor (part no. 1-794S) somewhere?
I was cleaning up the old carb purchased from thecarburetorshop along with their rebuild kit, and got overzealous trying to remove the throttle valve from the throttle assembly shaft.
Broke off one of the screws that hold it to the shaft :^/.
After researching, I learned the hard way that I should have left well-enough-alone: THE THROTTLE SCREWS HOLDING THE THROTTLE TO THE SHAFT WERE PEENED AT THE FACTORY TO PREVENT DROPPING INTO THE ENGINE.
Now looking at extracting the screw (and potentially having to retap a slightly larger hole).
The thecarburetorshop has been helpful with information sheets, videos, you name it, but they don't have flanges or the throttle shaft and lever assembly (3-781S) separately available. Would gladly sell me another old carb to re-start with :^/.
My '53 3600 has been a great truck to restore, great learning experience, therapeutic, and confidence-building. But I'm finding that the patience part takes time and a lot of self-discipline.
Maybe posting this will help alert other novices like myself to think twice before touching the carb flange :^)
TJSting120273600
Carburetion specialist
(1) heat the assembly with a propane (or better, if you have one, acetylene) torch to where the shaft is red hot in the area of the screw.
(2) DO NOT QUENCH, allow everything to cool.
(3) Once cool, from the side where the slot was, center, and drill a pilot hole smaller than the inside diameter of the screw thread.
(4) Dull a drill bit slightly larger than the pilot hole.
(5) Using a variable speed drill, just barely start the dull bit.
(6) Now GENTLY jam the dull bit into the brass, and spin the twisted remains of the screw out the back side, preserving the threads in the shaft.
TRY TO AVOID THE TEMPTATION TO USE A NOT-SO-EASY-OUT! wink
Jon
The Carburetor Shop
H Online: Content
Just to add a bit of technique to Jon's excellent info-----if you set up the throttle body in a drill press with a cross slide vise and use a very small center drill to make the initial hole, you'll be much less likely to get it off center. I've also had a lot of success with turning the drill chuck with a pun punch in the chuck holes instead of power-driving it when doing tedious work like this.
