6 members (Hanks custodian, TexasJim50, stlcardinalsguy, Woodcmiami, klhansen, 1 invisible), 54 guests, and 2 robots.
Topics128,059
Posts1,055,820
#1456775 06/29/2022 1:26 AM
I am installing a 1955 chevy 235 into a 1955 1st series 3600 pickup. I have a bellhousing 3837001. This is a 55-59 235 bellhousing that has the angles pads that are needed for 55 1st series trucks (correct?), and the bolt pads for foot starter. The question is.... I took the flywheel cover tin off another 1st series truck 235/4 speed and they are different bolt patterns than the 3837001 bellhousing. I dont know the casting number of bellhousing in other truck but looks exactly the same. ........ are there differences in flywheel cover tin for the 235's? are cars and truck tin different? do 3 speed and 4 speed transmissions have different tin? do different diameter cluctches have different tin? Just want to confirm what the exact issues are before I go searching for correct items. thanks..
Old Truck addict
1950 chevy 1 ton napco
1956 gmc 1 ton dually napco
1954 chevy 3/4 ton napco
1957 gmc civil defense napco panel
Curmudgeon
Curmudgeon
There are 3 pieces of sheet metal on the 6 cylinder bellhousing.
The Flywheel Under Pan (underneath flywheel), Extension (between the under pan and engine) and Inspection Cover (small cover at the top see section 0.686).
Below is the link to section 0.679. Cross out the years not applicable and V8 engine. Also the link for the bellhousings.
Search the Internet for corresponding pictures. There can be differences between car and truck parts of the same year.
PG=powerglide, HT=hydramatic, COM/utility=truck lightweight. PASS=car.
Sheet metal:
http://chevy.oldcarmanualproject.com/1929_57chevyparts/57cmpc0148.htm
and:
http://www.gmpartswiki.com/getpage?pageid=65950
Bellhousing:
http://www.gmpartswiki.com/getpage?pageid=65952
Here is my list of covers.
My Blog
