5 members (ShopRag, Pinetree, dt235sd, klhansen, Southerntruck), 85 guests, and 4 robots.
Topics128,263
Posts1,058,133
Members48,482
#1455983 06/22/2022 2:14 PM
Moderated
Moderated
My son bought me a 1946 GMC that has been sitting on a farm for a long time.
I have never worked on anything like this, and I am only an at-home mechanic who has learned everything by just doing it.
We want to get this running again, not looking for a full-on restoration but to make this drivable.
I am sure I will be needing A LOT of advice and I was told this was the place to get it.
So... HELP!
Welcome to the Stovebolt. That is a very cool truck and I think you will have lots of fun with it. You have come to the right place. Enjoy the journey!!
1951 1 Ton Completed
Welcome. #1 read every single Tech Tip several times over. Our Tech Tips will save you time, money and headaches. Click on the Tech Tips link in the Tool Bar at the top of every forum. Absolutely do not try to start the engine without reading the Tech Tip on resurrection of a dead engine. That tip alone can save you thousands of dollars. Good luck and check in often.
wave
Crusing in the Passing Lane
Engine SN is on right side behind distributor, stamped on machined pad. Starts with displacement, I e 248xxxx. Do not try turning engine over BEFORE removing valve cover, oiling valve stems and tapping them gently with a rubber hammer or 2 x 4. If stuck, tap gently while keeping them oiled ‘til they come loose. Otherwise bent pushrods may happen.
Ed
Welcome!
You will notice that the site has different forums for different parts of your project--i.e. engine, electrical, interiors, bodywork, etc. As you get into the project, be sure to ask your questions in the appropriate forum. Lots of help and good advice to be had here.
Rich
1947 Loadmaster
1947 Chev. Loadmaster
1959 Chev. Viking 40
SternLemur Cream Puff !!! Wow a real dandy read on,take your time ,soak your cylinders and watch out for your valve guides be sure to lube em !! Welcome!!
