Fixing the old truck
BUSY BOLTERS
Are you one?
Where is it?? The Shop Area
0 members (), 534 guests, and 1 robot.
Topics126,777
Posts1,039,270
Members48,100
Most Online2,175
Jul 21st, 2025
#1455741 06/20/2022 5:45 PM
In the process of cleaning up the pivot ball and noticed that it has a few dings in it ,has anyone welded or brazed the ball marks then filed and sanded them smooth for a better seal.
kevinski
1954 GMC 9300
KEVINSKI #1455756 06/20/2022 7:16 PM
If you're talking about the u-joint ball, yes, I've welded on mine and dressed it to smooth it out. I don't think it will help a lot with the seal weeping though. Mainly the welding was done on the inside where an exploded u-joint gouged the inside of the ball and put lumps on the outside.
KEVINSKI #1455767 06/20/2022 9:15 PM
Mine has some marks on the outside close to we’re the seal rides ,looks like at one time it was hammered on .I will fill the dings and smooth out ,some of the ones further on the ball I agree with you that they are not near the seal and as long as they move nice I will leave them alone I think brazing may be easier than the mig weld, but at least it can be done thanks Kevin.Kevin
kevinski
1954 GMC 9300
KEVINSKI #1455768 06/20/2022 10:09 PM
Yours looks pretty decent. I had to kind of fit mine into the transmission housing also. It had some wear spots where it mated with the socket. I painted it then put it in the transmission socket and worked it around to find where the high spots were (paint rubbed off) and sanded those down a bit. I don't have any pictures of mine. It was just too ugly. LOL.
(Release build 20240826)
Responsive Width:
PHP: 8.3.11 Page Time: 1.433s Queries: 15 (0.057s) Memory: 0.6089 MB (Peak: 0.6623 MB) Data Comp: Zlib Server Time: 2025-09-22 07:29:41 UTC
Valid HTML 5 and Valid CSS
