7 members (Otto Skorzeny, dt235sd, FAST55, FishinToms53, 3B, Rusty Heaps, 1 invisible), 100 guests, and 2 robots.
Topics128,115
Posts1,056,632
Members48,450
1950 Chevy 3100 216 3 Speed.
Where do I connect the wire to power the light on an original radio? Did this lead originally go on the key switch or the light switch?
Darren
Current Project - 1950 3100 5 Window with a rebuilt 216 and 3 speed trans
Great question.
I can tell you I wired my radio originally to the ignition..radio turned on . Light came on... but I later changed it to the llight switch.
Now turn on Lights, Radio light comes on. (Only reason is during the day driving around I see no reason for the radio light to be on the entire time.)
-T
1950 Chevy 3100
Originally the radio would have had a main power lead for the fuse and another wire that would power the dial light. That latter is meant to be connected to where the dash lights are connected on the headlight switch. This way the dial light is controlled by the dimmer. Sometimes if the switch has been replaced in the radio, there is no separate wire for the dial light,
1951 1 Ton Completed
Perfect. That makes complete sense. I do have a fused line to power the radio and a second line for the light. Thank you.
Darren
Moderated by  truckernix
