9 members (Bill Hanlon, Jon G, Ponchogl, dt235sd, rfs56trk, Steelonsteel, Maybellene, 49choptop, 1 invisible), 120 guests, and 2 robots.
Topics128,096
Posts1,056,478
Members48,444
#1455575 06/19/2022 1:33 AM
I'm at wits end with this and need a second opinion.
For the past few years by '53 3600 has had horrible front brake screeching, to the point where I don't want to drive it as its embarrassing and terrible to listen to. I've replaced the drums(Raybestos 2008R) and shoes(Napa FLT FT310), new springs, and made sure that everything was greased. It has a dual master cylinder conversion, I even replaced the master thinking that maybe it was sticking internally and causing the shoes to drag.
Nothing has worked. If I clean the brake dust and scruff the drums I can get ~10 miles of quiet driving before it starts acting up again. Any thoughts? I must be so far into the weeds that I'm overlooking the obvious.
Lots of older brake drums had a long coil spring resembling the one used to close a screen door wrapped tightly around the drum. It was there to dampen out the harmonics caused by vibrations when the brakes were applied. It's a low tech solution, but it works pretty well.
X2 on Jerry’s solution.
If a new drum doesn't have a groove just inboard of the reinforcing rib at the open side for the spring to fit into, it's possible to create one with a die grinder and a flame-shaped carbide burr by mounting the drum on a front spindle and slowly spinning the drum by hand against the burr. Wear safety glasses and gloves- - - -those shards of cast iron coming off the burr are sharp! It doesn't take much of a groove- - - -maybe 1/4" wide and 1/8" deep.
