1 members (tesa), 142 guests, and 2 robots.
Topics128,080
Posts1,055,953
Members48,430
Do y'all glue this to hold it in place or just kinda mush it in place? Thanks.
'38 1.5ton; "The stuff is as tough as woodpecker lips"
AD Addict & Tinkerer
There is a clip on the very bottom (latch side) that you slide the channel in to start and a screw just below the window opening, in which I didn’t install because it was too difficult. I used Pop rivets spaced ever four or so inches all the way up to the wing window (mine is a 52) and it seems to have worked perfectly.
There is a series of Videos on youtube by Jerry Kassis. It’s a 5 part series and episode 5 shows the installation of self taping screws. It cover the whole installation of all the door components and I highly recommend watching it.
Search for “1952 SBM Chevy PU door reconstruction & adjustment. Ep 5”
You may have to watch EP 4 to see the start of the channel installation.
Phil
Project Journals
Stovebolt Gallery Forum
Thanks for the video Phil mine is a 1938, Ill have to look closer but I think quite different from the '52.
back yard wrench turner
W Online: Content
I used pop rivets in my 38 window channel.
Wayne
1938 1-Ton Farm Truck
Stovebolt Gallery Forums
1989 Silverado
1996 Mustang GT convertible
More: What are these holes for? On the other side it looks like there are plastic things in them.. I dont imagine if its a screw that goes in there to hold the molding.. it cant go very far -wouldnty it scratch the glass?? headscratch
And that center metal clip. I dont know what that is for either.. ohwell
I carefully massage the window channel into the correct shape and mush in place. Cutting it to the proper length once you have the bends worked out is important.
Moderated by  ndkid275, Phak1
