3 members (FishinToms53, Shaffer's1950, Jman), 94 guests, and 3 robots.
Topics128,096
Posts1,056,487
Members48,444
Looking for some advice from somebody who has kept their 6 volt horn after converting to 12 volts…. I have tested the horn with 12 volts and it is incredibly loud, but I’m concerned that I’m going to ruin it if I don’t run a 12V-6V converter.
Do I need to run a converter? If so, what kind of amp rating would I need?
Any replies appreciated.
Thanks, Dave.
~ Dave
No, you are just fine. Just don’t lay on the horn for more that a few seconds at a time. In other words use it as you normally would.
Thanks. That’s great news. I really never use it while driving unless it’s to honk at a friend…. One less worry with my wiring!
~ Dave
Ex Hall Monitor
Ex Hall Monitor
Like Martin said, you'll be fine. When I was a kid dad would go to the salvage yard and bring home 6 volt horns every time we traded cars. He didn't think the 12 volt horns were loud enough. I went to 12 volts on my 53 and I'm using the stock horns. They will get your attention.
Driving in Atlanta I use the horn more than the brakes. It's the most important part of the truck!
1950 Chevrolet 3100 (Ol' Roy)
I have no clue as to the proper sounding horn(s) for my '54 truck. I did convert to 12v but want a sound as close to original as possible.
54 Chevy 3100 Deluxe 3 speed on column. Keeping original as possible but changed to 12 volt system.
JB Weld..."I put that stuff on everything"
As you noted, having no clue what the proper sounding horn sounds like, everyone else is in the same boat. So it really doesn't matter. ohwell
Been running my 6v horns with a 12v system for a few years now. No issues at all, except for scaring the pants off the guy in front of me while being on his phone........
Craig
Norcal Dave Here in deer country you want em loud to scare em back so they don't jump on the truck roof
