9 members (KEVINSKI, Sjm, tclederman, Oswald, Cosmo, Otto Skorzeny, mick53, 2 invisible), 145 guests, and 2 robots.
Topics128,260
Posts1,058,288
Members48,485
#14545 09/26/2002 1:38 PM
OK, what clearance should I be shooting for on the rod bearings in a rebuilt 216. Rods have been converted to inserts with stock dipper oil system. No shims I get about .0015. Some of the old Hot Rod books say to open this up to about .003. This ain't goin in a barn burner, just a stock resto.
#14546 09/26/2002 7:01 PM
I'm guessing you should either use the stock clearance or follow what the conversion rod manufacturer says to use.
Paint & Body Shop moderator
#14547 09/26/2002 8:33 PM
V
V Offline
Generally , .0015" ~ .003" will work fine .
-Nate
There is no problem so difficult it cannot be overcome by generous application of brute force & ignorance
#14548 09/26/2002 11:08 PM
I installed mine with .0015" last November , done nearly 10,000 miles since then , and they are SWEET . smile .
#14549 09/27/2002 3:29 PM
Thanks fellas, looks like the machine shop done good. Dusty,you still runnin the splash and dash oil system?
#14550 09/28/2002 7:39 AM
Yep ,, just a wee mod with the inserts in the rods ,,
Tools down the road at 55mph real sweet ,, ( '55 diff ,, 3.9:1) grin
