2 members (TUTS 59, Leo), 62 guests, and 1 robot.
Topics128,073
Posts1,055,908
Members48,429
#1454488 06/08/2022 10:34 PM
Trying to remove the u joint on my 54 gmc truck with a torque tube . I got the bell off and slid all the way back ,took the u joint bolts out and clips got the ends off and now I am stuck.The u joint won’t clear the bell to move out of the way .Anyone done this and is there a trick.
1954 Canadian GMC 9300
"The Journey"
Follow in the DITY
KEVINSKI #1454490 06/08/2022 10:39 PM
How are you supporting the truck to work under it? If you have jack stands under the axle tubes, the rear end will be forced forward by the weight on the springs. Use stands under the frame and let the rear end hang free. Also, be careful about unbolting anything with the weight of the vehicle on the springs- - - -the torque tube can slam down and injure you if you do manage to get the U joint disconnected.
KEVINSKI #1454492 06/08/2022 10:49 PM
Here’s a 1000 words
"The Journey"
Follow in the DITY
KEVINSKI #1454496 06/08/2022 11:03 PM
Thanks have the tube supported by a jack stand and jack stands on the rear axle will change to frame thanks jerry
"The Journey"
Follow in the DITY
KEVINSKI #1454500 06/08/2022 11:26 PM
Any other suggestions jack stands are under frame at back looks like less room by the u joint .
"The Journey"
Follow in the DITY
KEVINSKI #1454502 06/08/2022 11:28 PM
Another picture
"The Journey"
Follow in the DITY
KEVINSKI #1454503 06/08/2022 11:30 PM
Once you get the spring load off the torque tube, you might need to use a come-along to pull the rear end housing back far enough to disengage the driveshaft from the U joint spline.
KEVINSKI #1454504 06/08/2022 11:37 PM
I was just going to ask about that back in the garage thanks again Jerry update to follow
"The Journey"
Follow in the DITY
KEVINSKI #1454507 06/09/2022 12:07 AM
The torque tube U joint on the SM-420 is a little bit tricky. The front section on some of them is bolted to the output shaft of the transmission and the bolt can't be accessed until the spline is disconnected and the back half of the joint is swiveled out of the way. I believe the front section also has the speedometer drive gear attached to it. Servicing the U joint on a 3 speed is a lot simpler!
KEVINSKI #1454509 06/09/2022 12:10 AM
No luck took the shocks off put a ratchet on the axle to the trailer hitch at the back and not much is moving .looks like maybe loosen the axle from the springs to get the works to move back unless there are more tricks in the stovebolt chest .
"The Journey"
Follow in the DITY
KEVINSKI #1454510 06/09/2022 12:13 AM
On a side note from wiggling everything around I found the transmission rear bearing is loose most likely causing my noise .
"The Journey"
Follow in the DITY
Got it had to take the rear end off the springs ,lot of work done for today.
"The Journey"
Follow in the DITY
One more suggestion- - - -the fit of the pivot ball to the socket in the bearing retainer is adjusted by a stack of thin gaskets between the ball cover and the transmission. While it's disassembled, sand any score marks smooth and fit the pivot ball to the transmission with the appropriate gasket pack. The ball should pivot up and down with a firm push. If it's too loose, you'll have a leak. Too tight, and the ball will get scored and/or be noisy.
J M Offline
I would have to go along with Hotrod Lincoln's advice about taking the pressure off of the torque tube when disconnecting it. When I was a lot younger, I had one come down just missing me. Needless to say it got my attention and I have always put a safety chain on them after that. It sure got my attention and the chain is great for peace of mind.
Just for what it is worth.
Jim
J M #1454550 06/09/2022 5:24 AM
Jim
I have a scar over my left eye from getting nailed by a torque tube while changing the transmission on a '54 Chevy Station Wagon. That was when I was young and didn't know any better and was in the middle of an all-night job on the tranny.
On to the next step going to check locally for some new u bolts ,I have new rear mounts to put in before I take the transmission out ,I think it would be easier to jack up the transmission a bit to replace the mounts.I have a oakie bushing to put in ,I used the puller and only got the inner piece of the old bushing out going to try it again and hopefully the rest will come out .
"The Journey"
Follow in the DITY
Got the u joints no problem today was surprised a shop that has been around for a long time actually has several lengths of stock as well as diameters and they bend them on site for you .Looks like I won’t be using them for a while as the torque tube bushing puller only pulled out the inner brass and looks like it won’t pull the rest out ,it just slips very easily the puller is useless unless I can somehow modify it to grip the bushing better.I don’t really want to pull the rear axle apart to remove the bushing .
"The Journey"
Follow in the DITY
Some torque tube bushings are riveted in- - - -be sure you're not dealing with that type.
No rivets ,just need to make the puller spread out and grip better .seems to slip off easy now that the inner brass sleeve is pulled out .the tool should have a two sizes of the inner sliding ring to have more of a adjustment to push the teeth out to grip the bushing.
"The Journey"
Follow in the DITY
Okay I got it out .the puller did a fine job of pulling out the brass insert and after that it would slip on pulling the rest .I found a piece of pipe a little bigger than the inside of the puller and made a slightly bigger one to spread the teeth after a few tries it came out. Know does anyone know if the front bushing I pulled out has a ridge in the tube for it to stop against or should the tube be the same diameter all the way to the rear bushing/seal. To me I see a ridge we’re the front bushing has stopped against and I am wondering how the oakie goes past the ridge .thanks Kevin.
"The Journey"
Follow in the DITY
