6 members (Otto Skorzeny, Gdads51, 3B, 55shaker, Woodcmiami, 1 invisible), 262 guests, and 2 robots.
Topics128,086
Posts1,056,098
Members48,434
#1454106 06/05/2022 10:32 PM
Guys,
I have a 1950 3100 with a 216 motor. It has developed an oil leak after I shut the motor off that ends up being about a 6" circle on the ground. It appears most of it is coming out of the hole in the flywheel housing cover. It also looks like a very small amount is coming from the front oil seal and working its way along the bottom of the oil pan rearward. I have some questions:
Is the flywheel housing cover removable with the engine in the car?
Will that give me a better idea of where the oil is coming from?
Can the rear main seal be changed out with the engine in the car? Will only changing out the bottom half of the rear main seal be a worthless fix?
Do you have any guidance for this newby as to what I should be focusing on?
Thanks, Jerry
O Online: Content
Rear main seal and possibly the transmission itself. Check the oil level in the tranny.
1950 Chevrolet 3100 (Ol' Roy)
What Otto said, plus the pushrod cover. Look at the very back lower corner of the cover, just above the starter. Take a can of brake cleaner or like, spray and wipe the area clean then keep an eye on it. Jon G pointed me in that direction recently and a leak there was responsible for a lot of what I was calling a rear main leak.
Good Luck,
RonR
RonR
1970 340 Duster
1964 CJ5
Jerry M. Be sure your oil level is correct,if too full will leak like that. Cover is easy to take off,look with a good light,also if you have positive crankcase ventilation can affect it. On the other hand be sure the crankcase can get air so vacuum wont colapse your oil pan.
I hate to say it, but these trucks leak aka mark their territory. If it completely stops leaking, you are out of oil!
Hopefully you can slow the leak down.
Chris
Curmudgeon
Curmudgeon
It's called the clutch underpan. The shop manual says you can remove it to access the clutch retracting springs so I believe it should come off okay.
The flywheel is close to the block so you may not be able to see much.
The rear main seal is a common source for oil leaks at the rear of the engine.
There are metal plugs at the rear of the block that rarely leak oil.
There is also one large metal plug that rarely leaks and if it does, will be coolant.
Oil can also leak from the rear of the valve cover and sneak it's way between the clutch housing (bell housing) and the block.
The rear main rope seal needs to leak a little oil (weep) in order to form a seal.
Same as old tractors and boat propeller shafts.
Well, I checked the transmission fluid level today and that is still full, so it is not that. I have also removed the Clutch Underpan to get a better look at where the oil is coming from. I have a friend coming over this weekend to examine further and I will report back on what I find. Thanks for the suggestions.
buoymaker That is what mine does "weep" Keeps my side of the apron lubed,it's where I work on it so no problem !!
buoymaker Don't forget camshaft plug at the rear,can get knocked out.
