1 members (RLB),
215
Mod | | | Forums66 Topics128,094 Posts1,056,066 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2018 Posts: 760 'Bolter | | 'Bolter Joined: Aug 2018 Posts: 760 | Since I had to remove my distributor gear to re-pin it anyway, I decided to just completely disassemble the distributor for inspection and a good cleaning. The book shows a small bakelite disk at the inside end of the spring that is in the hole where the grease cup provides grease to the shaft. Mine did not have this bakelite disk, nor did it have anything else at that point. So my question is where can I find one of these disks, and if the answer is nowhere, then what would be a good substitute for it?
Mike Burns 1940 Chev 1/2 ton 1953 Chev 1/2 ton 1950 Studebaker Starlight Coupe 1947 Indian Chief 1943 Indian 741
| | | | | Joined: Mar 2017 Posts: 326 'Bolter | | 'Bolter Joined: Mar 2017 Posts: 326 | The washer is there mostly to keep the end of the spring from gouging out a groove (if I recall correctly). Any kind of hard plastic washer that is similar sized should work.
Lee.
1956 Chevy 3200, 235 w/3 speed
| | | | | Joined: Aug 2018 Posts: 760 'Bolter | | 'Bolter Joined: Aug 2018 Posts: 760 | I don't really know the size because I didn't have an old one to look at. I'm gonna dig through my extra junk to see if I have a spare distributor. Thanks
| | | | | Joined: Mar 2017 Posts: 326 'Bolter | | 'Bolter Joined: Mar 2017 Posts: 326 | Make sure you have the hole in the middle, I believe that is needed so the grease can get to the shaft.
| | | | | Joined: Feb 2004 Posts: 29,792 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,792 | The original discs don't have a hole- - - -no need to worry about the grease getting around a solid one! jerry
| | | | | Joined: Mar 2017 Posts: 326 'Bolter | | 'Bolter Joined: Mar 2017 Posts: 326 | Thanks for correcting me Jerry; it has been too long since I overhauled mine that I could not remember for sure if it had a hole or not.
Lee.
| | | | | Joined: Aug 2018 Posts: 760 'Bolter | | 'Bolter Joined: Aug 2018 Posts: 760 | Thanks for all of the good answers guys. I did end up digging an original disk out of a spare distributor and using it. As Jerry said, it did NOT have a hole in it. It seems to me that a tiny hold would have made sense, but GM didn't do it, so I'm not either
| | | | | Joined: Mar 2010 Posts: 10,279 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,279 | Was the original disk round? Or is it squarish with rounded corners to allow the grease to move in? I don't remember.
| | | | | Joined: Aug 2018 Posts: 760 'Bolter | | 'Bolter Joined: Aug 2018 Posts: 760 | My original was round. It's a loose enough fit that I'm sure enough grease gets around the outside.
| | | | | Joined: Feb 2004 Posts: 29,792 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,792 | I choose to modify the distributor housing to run a needle bearing at the top, and a hardened steel sleeve pressed over the shaft, ground for a wobble-free fit. Either a grease fitting or the original cup can be used to keep the bearing lubed. That eliminates the need for the disc and spring, and assures that the point gap stays consistent at least until the rubbing block or the cam wears. Jerry
