10 members (3B, Steveoreno, Bill Hanlon, moparguy, 66flea, dt235sd, Jay R, Phak1, Joe H, Goach2),
80
0
Mod | | | Forums66 Topics128,198 Posts1,057,272 Members48,466 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2006 Posts: 39 Member | | Member Joined: Jun 2006 Posts: 39 | I'm looking for two right hand studs for budd wheels for Cloey, my 1942 1.5 ton Chev military 4x4. These are 2" long overall, with 1~1/4" of thread, 16 TPI by 3/4" in diameter. The splines are pretty fine and the diameter of the splined area is about 7/8". (Sorry but the rain ate my micrometer last night).
I'M DESPARATE, no wait, Cloey is desparate! These may be the same studs as used on the larger Chevy and GMC duallys. I've already visitied with most of the well known Military parts guys.... No luck yet.
The good news, Cloey has new brakes seals and bearings all the way around! | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy Dale in Iowa, according to the spec's you gave us Euclid p/n E-4964-R looks like the closest match, hope that helps | | | | | Joined: Aug 2004 Posts: 242 Shop Shark | | Shop Shark Joined: Aug 2004 Posts: 242 | Dale; Frank VonRosentiel in Canada has NOS studs, his contact info is on the VOV site under "other resources"
John Gott 1942 G5106 1.5-ton Chevy cargo dump Gallery pageOld Dominion Stovebolt Society T/Sgt. Gott (28 years of service with the USPP) 1940 Chevy G506 4112 cargo dump 1942 Diamond T G509 969A 4 ton wrecker 1942 Ward LaFrance G116 series 2 10 ton wrecker 1944 Ward LaFrance G116 series 5 10 ton wrecker 1931 Ford AA with a WEAVER crane 1944 Sterling HC 165 tractor 1944 Autocar U7144T w/ 10 ton trailer
