8 members (Rusty Rod, GMCJammer51, Rusty Heaps, 68ironhead, carbking, Jeff Ogden, Gdads51, 1 invisible), 382 guests, and 4 robots.
Topics128,162
Posts1,057,042
Members48,463
#145381 01/13/2006 6:49 PM
How much oil does it take to fill a two speed rear end? I'm not sure I understand how it works. There are two fill plugs on the rear end. One in the place you normally find one on the ball in the axle, and one on the two speed itself. The one on the two speed in much higher than the one on the axle, which makes me think the two oil supplies are seperate. One for the two speed and one for the rear end itself.
What kind of oil do you put in the two speed. It is leaking, but there is still enough that I can find it when I put a heavy wire down the fill plug. It looks like plain old heavy gear oil to me, but I'm not sure. It that correct?
How near to being full should the two speed gear box be? Is it necessary that it be nearly competely full, or is about half full enough?
Once again, Thanks, Allen
Hey Allen,The double reduction rear end(2 speed) takes between 11 to 14 1/2 plus pints of 80-90(mill spec is 2105-c)gear oil initially.The front plug is for filling the system so as to bring gear oil to the two front pinion bearings right away if the system were dry as in new or just overhauled.The gear oil will drain back toward the rear cover if overfilled.For normal service,the oil is checked at the rear plug as any(most)rears would be.I blew my high range and had to overhaul it last year.What a big boy with 6:13(high range)and 8:10(low range)ratios.Hope this helps!
Wanted Good Woman:
Must be able to cook , clean , sew , tune engines and polish trucks. Must have old Stovebolt and garage. Please send picture of old Stovebolt and garage.
Thanks for the reply. Nothing has been done to the rear, so if I understand you correctly, I would just check the rear plug and ignore the front one. If the rear plug shows a normal amount of oil then I would be ok. Do you agree?
I am leaking oil at the front of the 2 speed where the drive shaft connects. It only leaks after I have moved the truck. I didn't understand that until now, but I suppose the oil drains to the rear when the truck is sitting which means there is oil to the front only when the truck is moving. Is that correct? Thanks Allen
Yes,Just check the gear oil level in the rear plug on the cover.Full,when it runs out on your head!Sounds like you will need a pinion seal.Not a bad job.Just take your time.The seal part # from Napa is 49429.If you want to remove the cover to look inside and see all those BIG GEARS, a clean pizza box makes good gasket material for the cover gasket.Use RTV sealant with it and don't overtighten the bolts.Good Luck
Wanted Good Woman:
Thanks for the gasket tip. Never would have thought of that. Allen
#145386 01/16/2006 11:33 PM
I wouldn't think the corrugated cardboard would seal well. Might have to give it a try on the 350.
1954 GMC De Luxe COE
GMCpanel
I think gTow is talking about a regular pizza box thats flat 1ply cardboard not the corrugated style,
Works purty good for alot of things.
regards
Junior Member
Junior Member
i like to use the boxes that a case of cold beer comes in
1961 c65 flat dump
1973 c50 flat bed
All the pizzas I get are in corrugated cardboard.
