0 members (), 73 guests, and 9 robots.
Topics128,077
Posts1,056,033
Members48,433
#1451753 05/15/2022 10:17 PM
the "nose" (where the tip meets the center piece) on driver's side of my '46 3/4 doesn't want to lay flat whether hood is latched closed or not. Rest of the hood seems to fit/lay well. The nose will press into place with limited pressure, but pops right back up when you "let go". Only up about 1/4 to 3/8 but the other side (passenger) lays flat.
I know there are probably 1000 causes . . . . Ideas?
When I did mine I would open one of the hood sides and give it a twist by hand, close check and try again, this took a bit of guts or lack of brains to try because if it gets away from you you can ruin the hood. Dave
1941 Chevy
"First rebuild - complete!"
Follow the story in the DITY
1941 GMC resting peacefully
1946/1947 Chevy Street rod on s10 frame complete
1945 GMC panel truck in line for restoration
1941 Plymouth stock complete
1941 GMC COE in restoration process
Read his Project Journal
1941 Chevy Coe uncertain future resting now
homer52 #1453800 06/03/2022 10:04 AM
I did the same.
1946 with WWII 270
