1 members (klhansen), 107 guests, and 1 robot.
Topics128,062
Posts1,055,856
Members48,428
#1453555 06/01/2022 2:32 PM
What are the 2 things above the temp sender. Also is that smaller hose necessary, it was just looped back down below
1952 GMC
Starting with a basket case
In the Project Journals
1967 GTO
1967 Firebird
They used to be thermal-vacuum switches- - - -used to turn emission controls and/or distributor vacuum advance or exhaust gas recirculastion valves on and off according to coolant temperature. Remove them and install pipe plugs instead if you want to clean up the cosmetics of the engine a little. Leave the bypass hose in place- - -it allows coolant to circulate through the block while the engine is warming up and prevents hot spots that could blow a head gasket or crack a cylinder head. If the proper thermostat is used, the bypass gets blocked off as the thermostat opens.
pauld #1453681 06/02/2022 12:52 PM
Thanks for the info Hotrod
1952 GMC
1967 GTO
1967 Firebird
