Fixing the old truck
BUSY BOLTERS
Are you one?
Where is it?? The Shop Area
1 members (Truckrolet), 504 guests, and 1 robot.
Topics126,777
Posts1,039,268
Members48,100
Most Online2,175
Jul 21st, 2025
1954 gmc question.Does the rear fender inside were the running board attaches have a metal support that matches the shape of the running board or is there just regular washers used were the bolts attach the two together .Kevin
kevinski
1954 GMC 9300
The fender should have a "doubler" strip on the inside that's about an inch wide IF factory. Many repros don't have the reinforcement strip and you have to make it. We use a generous amount of 3M Panel Bond so it squishes out all around the strip which won't allow water/dirt/salt to collect between the tin layers and cause rust out.
Evan
Thanks Evan the truck has original fenders but looks like they were repaired years ago and the doubler was missing.Kevin
kevinski
1954 GMC 9300
The original design of that area was just fine for the original purpose of these tractors which kept farmers dry when it rained.
For a truck which we spend thousands of dollars to build, not so much. Tar paper and a thin metal doubler is a horrible idea. I did it anyway on mine.
I had considered not attaching the rear fender to the running board at all and add a fender brace rod from the fender to the frame similar to what was done at the rear end of the fender to keep it from flopping around.
(Release build 20240826)
Responsive Width:
PHP: 8.3.11 Page Time: 0.237s Queries: 14 (0.044s) Memory: 0.6072 MB (Peak: 0.6447 MB) Data Comp: Zlib Server Time: 2025-09-22 06:04:33 UTC
Valid HTML 5 and Valid CSS
