BUSY BOLTERS Are you one? The Shop Area
| | Click on image for the lowdown.
7 members (sron48, J Lucas, Hotrod Lincoln, klhansen, Peggy M, Rich'sToys, 1 invisible),
536
robot. | Key: Admin,
Mod | | Forums66 Topics126,777 Posts1,039,265 Members48,100 | Most Online2,175 Jul 21st, 2025 | | | Joined: Sep 2010 Posts: 1,955 'Bolter | 'Bolter Joined: Sep 2010 Posts: 1,955 | 1954 gmc question.Does the rear fender inside were the running board attaches have a metal support that matches the shape of the running board or is there just regular washers used were the bolts attach the two together .Kevin | | | | Joined: Apr 2005 Posts: 2,832 'Bolter | 'Bolter Joined: Apr 2005 Posts: 2,832 | The fender should have a "doubler" strip on the inside that's about an inch wide IF factory. Many repros don't have the reinforcement strip and you have to make it. We use a generous amount of 3M Panel Bond so it squishes out all around the strip which won't allow water/dirt/salt to collect between the tin layers and cause rust out.
Evan
| | | | Joined: Sep 2010 Posts: 1,955 'Bolter | 'Bolter Joined: Sep 2010 Posts: 1,955 | Thanks Evan the truck has original fenders but looks like they were repaired years ago and the doubler was missing.Kevin | | | | Joined: Mar 2010 Posts: 10,059 Renaissance Man | Renaissance Man Joined: Mar 2010 Posts: 10,059 | The original design of that area was just fine for the original purpose of these tractors which kept farmers dry when it rained. For a truck which we spend thousands of dollars to build, not so much. Tar paper and a thin metal doubler is a horrible idea. I did it anyway on mine. I had considered not attaching the rear fender to the running board at all and add a fender brace rod from the fender to the frame similar to what was done at the rear end of the fender to keep it from flopping around.
