| | | Forums66 Topics128,089 Posts1,056,139 Members48,435 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2018 Posts: 760 'Bolter | | 'Bolter Joined: Aug 2018 Posts: 760 | Today I blasted my exhaust manifold, coated it with Calyx, and removed a broken stud from it. Then I got ready to attach the intake manifold. The holes in my intake to exhaust gasket are about 5/16 inch too narrow to slide over the studs in the exhaust manifold. I had ordered a complete gasket set for my engine which, according to the numbers, is a 235 engine from a 1962. Chevy P10 truck. So, I have to assume that this manifold is probably from a different year and / or a different engine. I"d like to know, so that I can buy a single intake to exhaust gasket, since all of this stuff is cleaned up, coated, and ready to use. Can you guys tell me what my exhaust manifold is off of?
Mike Burns 1940 Chev 1/2 ton 1953 Chev 1/2 ton 1950 Studebaker Starlight Coupe 1947 Indian Chief 1943 Indian 741
| | | | | Joined: Jan 2000 Posts: 2,074 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 2,074 | Take some photos, Im sure you will get lots of good input. | | | | | Joined: Aug 2018 Posts: 760 'Bolter | | 'Bolter Joined: Aug 2018 Posts: 760 |
| | | | | Joined: Feb 2004 Posts: 29,798 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,798 | 216 and 235 intake/exhaust assemblies have a different bolt spacing where the manifolds bolt together. It's possible you have either the wrong gasket, or maybe an incorrect intake and exhaust manifold assembly for your engine. The diameter of the intake ports are also different between a 216 and a 235. Do the studs and bolt holes on both manifolds align properly? Jerry
| | | | | Joined: Aug 2018 Posts: 760 'Bolter | | 'Bolter Joined: Aug 2018 Posts: 760 | Yes, my intake and exhaust bolts and studs mate up perfectly. The gasket just doesn't match. I would guess that my manifolds are probably not correct for my engine, even though I did take them off of this same engine. I checked another manifold set that I have here, and the gasket matches them. Of course they're still all crusty and covered in road cheese, so I was just hoping to use the ones that I made ready for use. I guess that I should determine which manifolds are best for my engine performance, and then use them. Can anyone tell me what to measure in order to determine that?
| | | | | Joined: Aug 2018 Posts: 760 'Bolter | | 'Bolter Joined: Aug 2018 Posts: 760 | I checked my spare manifold set and it not only matches the gasket, but the intake ports are 1/8 inch bigger. So, It's probably more correct for my motor anyway. Just cost a days time is all.
| | | | | Joined: Feb 2004 Posts: 29,798 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,798 | OK- - - -good progress! The manifold assembly with the smaller intake port is for a 216 or a spray oiler 235, which also had smaller intake ports in the head. It can be used on a late model 235, with stepped-down alignment rings to mate it to the cylinder head, but high speed engine performance will suffer a little. 54-up 235's had bigger ports and manifolds matched to them. The spacing of the carburetor studs will also be wider on the 235 intake manifold. Jerry
| | | | | Joined: Apr 2021 Posts: 28 'Bolter | | 'Bolter Joined: Apr 2021 Posts: 28 | hi all, i am swapping out my 236 for a 350 v8 chevy small block into my 1954 3100. have a new crate engine and getting a rebuilt manual T5 shipped to me as we speak. installed a mustang IFS suspension along with powered rack & pinion steering. wondering what exhaust manifold would fit. would a standard manifold work? Before i buy something and it's in the way of something. by the way It's going to be a weekend driver no hot rod.
thanks
1954 Chevy 3100 with a straight 6cyl
| | | | | Joined: Mar 2010 Posts: 1,660 Curmudgeon | | Curmudgeon Joined: Mar 2010 Posts: 1,660 | Moeman I would post that question separately in the HiPo Shop section.
"Adding CFM to a truck will only help at engine speeds you don't want to use." "I found there was nothing to gain beyond 400 CFM." | | |
